Results 1 to 8 of 8
Thread: New sand filter and pump, what is best?
    I have a 48 x 24 ft above ground pool, approx. 28,000 gallons. I want to get a new sand filter and pump and don't know what is best, keeping cost in mind. I currently have a hayward pump and filter that are definately too small (were from a 24' round). What do you suggest?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: New sand filter and pump, what is best?
    Many times pools are sold with oversized pumps and undersized filters. You probably want to consider something like a 27 or 30-31 inch filter and a 1HP. If you live someplace with high electricity rates, you may want to consider a 2-speed or variable speed pump. Inground equipment will work fine for your pool, and tends to be better quality.
    Do you have a cleaner or SWCG that might affect your pump needs?
    Thank you for your help. I did make a typo and the length of my pool is 42 ft. Would that make a difference on your suggestions?
    SW Indiana
    9,199
    Quote Originally Posted by denmark85
    No, I based it on gallons.
    I have a Polaris that I use about once a week and I'm not sure what a SWCG is.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Which Polaris? Does it run off a booster or from the pump? Is it suction side or pressure side?
    SWCG = Salt Water Chlorine Generator - an alternate way of giving your pool chlorine. The reason he asked is that you need the pump on while the SWCG is running.
    Polaris 165, as for chlorine, they're the 3" tabs in containers that float around in the pool.
    Jun 2012
    Mint Hill, NC
    2,589
    Polaris 165 is primarily for in-ground pools - I don't know why they say that and the 65 is for AGP. My suspicion is there is something in the pump requirements that is related. I'm afraid I don't know.
