Thread: Generic filters vs OEM
    I have an Artesian spa that uses (what I believe is) a Unicel 6CH-502 filter. Different online spa supply shops offer everything from Artesian OEM part to a cut rate filter that "replaces Unicel 6CH-502." How important is it to use a manufacturer's OEM part vs. brand name (Unicel) vs. cut-rate "replacement"?
    38,475
    Re: Generic filters vs OEM
    I have not experience with cartridge filters, but I imagine they are pretty similar. The OEM is likely one of the name brands Unicel/Filbur/etc. There is a chance that the cheap ones are also built in the same factory.
    Depending on how different the price is, might be worth a try. They will all certainly work, but there is a chance some may not work as well as others.
    Just like everything else out there, there are generics ... should be the same, but might have minor differences. At least this is not as important as a car oil or air filter which could result in expensive repairs ... your spa just may be a little less sparkly.
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    I found cartridges for my previous filter for 1/4 of the cost of the name brand. Seemed to have worked just fine. And, I figured I could replace them 4 times as often if needed.
    14.5K gal Plaster IGP, Intelliflo VS, EasyTouch 8, SWG, IntellipH, Clear and Clean 420 Cartridge Filter, Attached Spa, H400IDL2 NG Heater
    mas985's Avatar
    Pleasanton, CA
    11,741
    Some distributors have indicated a difference in manufactures. They recommend OEM, Unicel and Wilbur. But Pleatco are definitely lower quality thinner material as are some of the filters from China. I have heard this from multiple sources but I have not directly experienced other brands.
    Mark
