Results 1 to 8 of 8
Thread: A couple of chemistry questions
    Granite Falls, WA 98252
    8
    I've recently switched over to the BBB method and my pool water is looking pretty good. I do however have a couple of questions regarding TA and CYA for my pool.
    What should my TA target be now that I've introduced Borates into the pool? My current TA test is showing about 60ppm which is at the low end of the spectrum but before I add any sodium bicarbonate I'd like to know what my target should be taking the borates into consideration.
    The second question I have is regarding CYA levels in an indoor pool. My pool receives almost no direct sunlight and is testing at 0 ppm for CYA. Is there any reason to increase my CYA level?
    My current chemistry numbers are...
    Salt 3100 ppm
    pH 7.4-7.6
    Borates 50 ppm
    CH 210 ppm
    FC 5 ppm
    TC 5 ppm
    TA 60 ppm
    CYA 0 ppm
    As always, thank you for your input and guidance.
    - Chad C
    Indoor 15K gallon, in-ground, fiberglass, saltwater pool and spa (San Juan kidney shaped pool installed in 1989)
    Pentair Titan II sand filter
    Pentair WF-23 WhisperFlo pump
    BioGuard Mineral Springs MS-10 chlorine generator
    TF-100 test kit
    BBB Method subscriber
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: A couple of chemistry questions
    If your PH is stable, there is no reason to adjust TA. CYA of 20-30 ppm is recommended, not for protection from sunlight but rather it is much easier to manage FC level at perhaps the 2-4ppm level, vs being more precise in the 0.2-1ppm range
    8
    Quote Originally Posted by dmanb2b
    Thank you for the quick reply. The pH is fairly stable but it does tend to drift upwards requiring about 30-40 oz of muriatic acid per week to stay within the 7.4-7.6 range.
    TF-100 test kit
    Oct 2011
    New Caney, Texas
    414
    The below is taken from Pool School
    Second adjust CYA to between 70 and 80. The biggest mistake that many SWG owners make is NOT having enough CYA in the water! This can create a lot of problems like high acid demand, algae outbreaks, cloudy water, or early cell failure.
    http://www.troublefreepool.com/pool-...ater_generator
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by George N
    Yes, but this is an indoor pool
    To help avoid confusion, I'll move this thread to Chem 201.
    You're done SLAMing when:
    Mar 2007
    San Rafael, CA USA
    12,082
    If you have no CYA in the water, then a high FC of 5 ppm has over 50 times the active chlorine level of what is recommended here on this forum! The chlorine will outgas from the water that much faster and will oxidize swimsuits, skin and hair that much faster as well and also produce disinfection by-products faster and in greater quantity (for nitrogen trichloride). So having 20-30 ppm CYA would be better and then keep your FC at around 2 ppm FC. You should find your chlorine demand lowered so that will let you lower your SWG on-time and that can help reduce the rate of pH rise.
    The attached spa probably has aeration from jets and that will tend to drive up the pH, but keeping the TA lower should help. So I'd leave the TA where it is. Also, see what happens if you let the pH rise up more. It should slow down in its rise as the pH gets higher so you might be better off targeting 7.8 as your "goal" pH. If the pH continues to rise at a fast rate even as the pH gets higher, then the source of the rise is not carbon dioxide outgassing, but could be chlorine gas outgassing or something else unexplained. If your SWG is close to the first return in your pool, then the chlorine gas may not have enough time to dissolve in the water. You can try pointing your return downwards to see if that helps.
    Oct 2011
    New Caney, Texas
    414
    Quote Originally Posted by Butterfly
    My bad
    Thanks for the education Butterfly
    8
    Quote Originally Posted by chem geek
    Thanks for the suggestions CG. I'll leave the TA where it's at and tinker with the CYA level and SWGC settings a bit and see if I can bring the pH drift under control. I'll also let the pH come up a bit to see if it stabilizes around 7.8 as well. The water is looking good and the pH drift is pretty slow right now but if I could drive down the acid demand to 1/2 or 1/4 of what I'm using now that would be fantastic.
    TF-100 test kit
