Thread: Reflecting on the past pool season brings a question
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Well, I've taken down my Easy Set pool and I'm looking at the ground where it was. Still level, but definitely going to do it different next year with some extra padding and such.
    Anyway, one of the biggest annoyances for me last year was whenever it rained (ok, I live in Arkansas - it only rained 3 times this summer), or when the kids splashed water out of the pool, it would collect around the bottom of the pool - because the ground was level. It made the bottom of the pool pretty nasty.
    Anyone else have this problem? If so, how did you address it?
    Thanks!
    16x48 Intex Ultraframe vinyl AGP, 2150 gph sand filter/pump (Intex SF70110), Hayward Skimmer, TF-100 test kit
    Aug 2011
    Gainesville, fl
    53
    Re: Reflecting on the past pool season brings a question
    I put a tarp under mine this year. When I took it down to level again after a wash out from a tropical storm the bottom was a lot cleaner than last year. I have not taken mine down yet for the year but will probably in 2 weeks or so, I am pretty sure it will be almost as clean as it was when I put it back up.
    12"x33" Summer Escapes AG Ring Quick set 1590 Gallons (Gift for my son by Grand-parents)
    Intex Krystal Clear Model 633 2500 GPH "B" Cartridge
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I put black plastic around the outside edge around 2/3 of the pool.(ran out of time and energy to finish) where there wasn't plastic, it was a mess. Building some sort of deck next year, then want to put landscape rocks over the plastic. It should eliminate the problem.
