Thread: Help with setup
    Help with setup
    Here are photos of my pump/filtration setup:
    The port for the vacuum:
    My question is about the two valves. I know one has some control over the skimmer but here is my problem..
    I recently added a salt system, and when they did it they turned one or both of the valves because the water was low and I was not here at the time so when I came back the skimmer was not working. I got the skimmer working again, however my vacuum navigator thing no longer works when it is connected to the port for it. It seems to not be getting enough suction to move. Now if I take it out of there and connect it to the skimmer it works fine.
    Could someone help me with this?
    22,544
    Re: Help with setup
    Have you tried opening that middle valve?
    If you have open it and close the left one.
    Re: Help with setup
    I've tried turning both both ways. The middle one when it is in the position its in now makes the pump have a strange noise like a bunch of air rushing through it. Also when it is in that position it makes the vacuum run faster when it is connected to the skimmer. Has no effect on the actual vacuum port though.
    22,544
    Re: Help with setup
    You need to spend some time figuring out what each of the suction lines go to.
    Since the middle one increases flow through the skimmer it's either the vacuum line or the main drain.
    Did you have the vacuum plugged into the port when you opened the valve?
