Thread: Umbrella bottom for baja reef
    Jun 2011
    Fullerton, CA
    31
    We are remodeling our pool and adding a baja reef. The pool builder said to get umbrella bottoms (pole) that is stainless steel. We've not been able to find any. Since the pool may corrode the pole, I assume that we should get something in stainless or fiberglass or ...?
    Does anyone has experience of what works? Also, where do you go to buy the bottom piece of an umbrella pole in the chosen material?
    Thanks.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Umbrella bottom for baja reef
    How about just PVC pipe with a cap? I know lots of people have umbrella sleeves, hopefully they'll stop by and help.
    Jun 2011
    Fullerton, CA
    31
    Thanks. DW would like something nice looking. I'll keep this in mind though.
    Some of the other threads on thisnsubject inferred that the alumimum didn't corrode before the fabric deteriorated to where replacement was neccesary. I''m looking at purxhasing from California Umbrella myself because they have optional taller 'bar height' poles available.
    8.5k gallon IG pebble sheen play pool with Intellitouch control, Intellifo VF, IC 20, Rainbow tab feeder (not currently in use), Pentaire mystery cartridge filter with labels faded to the point I have no idea on the model, Intellibrite 5g LED light, Hayward Navigator. Adding IntelliPh and Crestron control next.
    Here is one you can order online.
    http://www.poolsupplyunlimited.com/best ... US107/5843
    35,000 gal, 3.5-9ft with diving board. Jandy CV580 filter, 2hp 2 speed motor, Pentair Ultra Temp 120 H/C heat pump. Pentair IC60 swg.
    Jun 2011
    Fullerton, CA
    31
    Thanks. I will follow up on the suggestions.
