Results 1 to 7 of 7
Thread: I need help with borates
    acadianarose's Avatar
    Lafayette, Louisiana
    28
    After 2 months, I finally got my alkalinity down to 70 so I could add borates. I used Proteam Surpreme Plus because it was ph neutral. Now my ph is over 8 and TA is 130. What am I missing? Did I still need to add muratic acid?
    Thanks once again for your help
    Linda
    BTW- the water looks absolutely beautiful. It is always clear but never so shimmery.
    12 x 23 Fiberglass IGP Built 2012
    24 inch rainfall
    2 HP Superflo pump
    Intellichor SWG
    Pentair Clean & Clear Cartridge Filter
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Re: I need help with borates
    Adding acid to get your pH back down where it belongs will also lower your TA.
    chiefwej
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    That is puzzling.
    28
    Quote Originally Posted by UnderWaterVanya
    That is puzzling.
    I know. I can't figure out what happened
    24 inch rainfall
    2 HP Superflo pump
    Intellichor SWG
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,770
    Per my other thread comment...as you know I had the same issue with proteam supreme plus, which makes me suspect that supreme and supreme plus may have been mispackaged or MIS-mixed. Or perhaps they meant "comparative" because perhaps it will require far less acid to get it settled down.
    I did use dudadeisel boric acid to retop midsummer and 10 lbs did boost TA by about 15, but it went back down on it's own after about a week and it did not raise my ph much at all.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    If you add a Boric Acid product, do you need to add less than if you used Borax?
    Mar 2007
    San Rafael, CA USA
    12,082
    Welcome to TFP!
    Yes you add less. Use The Pool Calculator to calculate dosages. To add 50 ppm Borates in 10,000 gallons with boric acid you would add 382 ounces weight (about 410 ounces volume) while with 20 Mule Team Borax it's 589 ounces weight (about 564 ounces volume) and you'd also have to add 281 fluid ounces of full-strength Muriatic Acid (31.45% Hyrochloric Acid). Note that borax pool store products are sodium tetraborate pentahydrate so would use 450 ounces weight and the same acid as with 20 Mule Team Borax.
