Thread: "Closing" a pool in Southern California
    Jun 2011
    Santa Barbara, CA
    30
    As the weather gets colder, I'd like to "close" my pool in Southern California. I've certainly noticed the reduced chemical requirements in the winter, but I'd like to run the pump less in the winter as well. Normally I target one full turnover a day during the summer. In the winter in Southern California, how low can I go on filtration? Will 1/4 a turnover a day be enough to circulate the chemicals I do add and to suck up the leaves and debris? I have a suction crawler that is always in place.
    Currently I run filtration for ~16 hours at 15GPM if the solar isn't engaged. I'd love to bring that down to 3-4 hours a day, as our electric rates are pretty high.
    31'x15' 19k gallon IG plaster/paint pool, 3 HP Intelliflo VF pump, 400 sq-ft DE Filter, 320 sq-ft Solar Panel, 400k BTU NG Heater (Unused)
    450 Gallon Marquis Epic Spa
    38,251
    Re: "Closing" a pool in Southern California
    It takes very little run time to circulation the chemicals, so 3-4 hour is likely plenty. Another option would be to split the run times up so that the pool circulations twice a day.
    This may not keep the pool free of dirt and crystal clear, but if you maintain the FC, it will not turn green.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    We don't really close here. Chemical usage goes way down when the water cools down below 60. I run my filter about 2 hours a day in the off season, plus whatever it gets when I vacuum or pump the level down before a rainstorm.
    pH is critical. Green can be removed easy enough with bleach, but scale is not so easy, and you probably have hard water.
