Thread: walmart cartridge filter
    Apr 2008
    clinton ms
    6
    anyone know who makes walmart cartridge filters 'A' type for intex pool? i ordered C-4607 unicel poly fiber filter from poolsaz thinking it would be so much better, but after it arrived, it appears to be same one as local walmart sells??
    thanks
    i own 15' intex pool and plan to use the same pump (637 800gph) again this summer!? maybe ill run it 24/7?? not sure if turning it off and on saves that much money vs maintaince..
    own intex 15' above ground metal frame pool
    cartridge filter pump model 637 800gph
    Guest
    Dont know about the Walmart filters but the Intex A filters are paper and are NOT washable while the Unicel (and Worldpool/Aladdin and Pleatco) are poly and are washable. They look the same but on close inspection of the pleats you can see the difference (the Intex being thinner). Are the Walmart ones disposable or washable? THAT will answer your question.
