Thread: New member in Granite Falls, WA and THANK YOU
    Granite Falls, WA 98252
    8
    Greetings and THANK YOU from a short time member and first time poster.
    I purchased a house with an indoor pool back in July and am a first time pool owner. The previous owners took pretty good care of the pool and have made some upgrades to the pool equipment over the years. They even took the time to show me how to use/maintain the equipment and go over some of the basics of water chemistry with me.
    There are some problems with the pool related to the age of the pool (23 years old) such as a ladder that was rusting at the waterline and what I suspect was the culprit of some fine rust spots (dots) on the bottom of the pool. There is also some degrading of the gelcoat (fiberglass pool) that has caused some discoleration of the pool surface, but that is more of an aesthetic problem than a functional problem.
    Upon taking over the house and the pool I immediately made two mistakes. I started testing with strips and taking advice from the local pool chemical supply store. At the time, I was unaware that the test strips could be wildly inaccurate and as a result of trusting them, my pool chemistry got a bit out of control. To make matters worse, the pool supply store had me test for phosphates as I am using well water (after the filtration system) to fill the pool. The phosphate tested positive and I purchased the chemical the pool store recommended and added the recommended dosage and was immediately treated to opaque water that took weeks to clear up. Additionally I was told to add chelating agents to my pool to counteract the effects of the rusty ladder on my pool chemistry. I did add the chemical but at the time the water was already so cloudy I could not discern any visible effect.
    Dismayed at the general direction the pool was going in I started reading everything I could on the internet about maintaining my pool and search after search kept bringing me back to the TFP website. After reading thru Pool School and several other helpful forums specific to some of the problems I was having with my pool I ditched the strips and stopped looking to the pool chemical supply store for advice. 3 weeks ago I started using the TF-100 test kit and implemented the BBB method of maintaining my pool. In about a week, my pool went from cloudy and out of control to crystal clear and easy to maintain. I'm now testing every day and find that I don't have to do much to keep my pool looking tip top. I'm adding a little bit of muriatic acid every week as the pH tends to slowly drift upwards and other than a little sweeping and vacuuming now and then, the pool is fairly maintenance free and I've had 2 weeks of crystal clear water and we've been using the pool every day. Thanks TFP for all of the good advice and helping a novice like me get some some control over his pool.
    Indoor 15K gallon, in-ground, fiberglass, saltwater pool and spa (San Juan kidney shaped pool installed in 1989)
    Pentair Titan II sand filter
    Pentair WF-23 WhisperFlo pump
    BioGuard Mineral Springs MS-10 chlorine generator
    TF-100 test kit
    BBB Method subscriber
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New member in Granite Falls, WA and THANK YOU
    Welcome to tfp, CC
    Your username is not something we like around here
    Quote Originally Posted by CC
    Jun 2012
    Blaine, MN
    106
    How about some pictures?
    blondemarcello
    18x33 16,700 gallon AG
    Sand, TFP Test, Gas heater
    Minnesota
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    8
    Quote Originally Posted by linen
    lol, I just used my initials. It didn't occur to me I was using a common acronym on the site when I picked my username. I'll have to look into changing that...
    TF-100 test kit
    8
    Quote Originally Posted by blondemarcello
    I just uploaded a couple to the "Show off your Swimming Pool..." forum
    http://www.troublefreepool.com/indoo...wa-t53038.html
    Enjoy!
    Chad C
    TF-100 test kit
