Hi
I have a pool that was built in '74 and it's about time to resurface it. It was painted and retiled by the previous owner. I got a few quotes and wanted to share to see if they're inline with what to expect in the San Gabriel Valley area. Any comments or tips are welcome Thanks!
Contractor 1 (probably won't go with this one)
108 linear ft pool and spa
$4000 standard White Plaster. Includes 3 drain covers and 7 jet fittings.
$2324 perimeter standard tile. national pool tile.
$150 Trim tile
$200 Silicon seal for tile meeting coping
$600 pool and spa light (incandescent)
retain sweep port
retain fill line
OPTION
+$3000 Pebble (brand not mentioned)
demo, plaster and tile done by in house crew
startup not included
no warranty against tile coming off
workers comp, bond, does not have liability insurance
no payment until customer is satisfied with job.
$7274 total for standard white plaster
$10274 total for pebble
Contractor 2
118 linear ft pool and spa
$4366 standard White Plaster
$72 3 8" drain covers
$119 7 eyeball/jet fittings 3 pool, 4 spa
$2625 "Super selection 200". master tile, longust, national pool tile.
$275 Trim tile (white plaster and quartz only)
$141 Silicon seal for tile meeting coping
$576 pool and spa light (50' incandescent)
Remove sweep port
retain fill line
OPTION
+$413 standard plaster hardening additives, polymers and pozzalans
+2596 quartzscapes(upgrade colors)
+$2950 Stonecape group B colors Pebble (brand not mentioned)
Demo is contracted
all plaster and tile work done by in house crew
has workers comp, bond, liability insurance
$8587 total for Standard white plaster w/hardening additives
$10770 total for quartz
$11124 total for stonescape
+$475 startup chemical and brush
Contractor 3
## linear ft pool and spa
$3884 standard White Plaster
$72 2 8" drain covers
$300 1 channel drain cover on existing single suction
$80 4 eyeball/jet spa
$60 3 eyeball/jet pool
$2310 Groups 1-4, longust, national pool tile, fujiwa tile.
$336 Trim tile (white plaster)
OPTION
+$744 50% crushed quartz rock mix
+3534 PebbleTec Cat 1
+3824 PebbleTec Cat 2
+3534 PebbleTec Cat 3
+3817 PebbleSheen Cat 1
+4101 PebbleSheen Cat 2
+4902 PebbleSheen Cat 3
Remove sweep port
retain fill line
does not include pool and spa lights
includes 3 day startup chemical and brush
all demo, plaster and tile work done by in house crew
$7927 total for Standard white plaster w/ 50% crushed quartz mix
$11415 PebbleTec Cat2
$11692 PebbleSheen Cat2
Contractor 4
94 linear ft pool and spa
$5283 standard White Plaster, 2 8"drain covers and return jets included
$425 1 channel drain cover on existing single suction
$2924 Groups A&B, master tile, national pool tile, fujiwa tile.
$280 Trim tile (white plaster)
$260 mastic for tile meeting coping
$630 pool and spa light (50' incandescent)
OPTION
$231 build up wall between spa and pool and cut for spillway.
Remove sweep port
retain fill line
does not include startup chemical and brush
$10033 total for Standard white plaster w/spillway buildup
PebbleTec and PebbleSheen available but not included in quote
