Thread: Pool base suggestion while dodging rain
    My self install if so far so good. Walls are set, ring wall poured, sump and drains in, backfilled with 8/9s to about 20", plumbing done and tested. I am ready to either Pool Crete or sand/cement mix the bottom prior to installing the liner. We keep having rain every few days so this is getting difficult to tack myself and miss the rains. Any suggestions? Whould the Pool Crete hold better once it dried? I will need a few days to get the bottom in and am afraid to just use the grout mix if I won't get the liner in immediately. Any suggestions or experiences would be appreciated.
    Nov 2011
    Moberly,MO
    1,010
    Re: Pool base suggestion while dodging rain
    We have done pool base for thirty years. That is the way I would go.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
