Thread: New Propane Hearter
    Jul 2011
    Webster,Wi
    59
    New Propane Hearter
    Earlier this summer I was given a Raypak hearter that was about 10 years old, when it did run it worked fine but would quit alot. So we have decided that we are going to purchase a new heater. Being that we have a salt water pool is it necessary to buy one that is for a salt pool or will any heater work as long as water levels are good?
    18'x52" Intex round AGP, 2650 Krystal Clear SWG pump with sand filter and a Hayward H100ID pool heater. TF100 test kit to keep the water sparkly clean.
    Qwaxalot's Avatar
    Jun 2012
    439
    Re: New Propane Hearter
    I would strongly recommend that you get a heater with a cupro-nickel heat exchanger. It doesn't add much cost, and substantially extends the life of the heat exchanger (the most expensive part of a heater).
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Jul 2011
    Webster,Wi
    59
    Quote Originally Posted by Qwaxalot
    Is there any place better then the other for ordering a heater, we have ordered things from Doheny's in the past but was wondering if I should go through a place that sells just heaters.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    It is not necessary to get the cupro nickel unit as long as you keep your chemicals in balance. You might want to consider a unit that has a two year warranty such as one of the Pentair models. I prefer Raypak/Rheem as they are the simplest units and usually have the least amount of issues with them.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
