Thread: pool numbers
    Round Rock, Texas
    11
    pool numbers
    Hey Gang,
    Ok, so I put up my pool last week, using BBB method. Water looks beautiful...added some cya (using sock method) and it has come up, however my pool seems to not be holding chlorine very well...any suggestions.
    Here are the pool numbers from 10:18 this am.
    TC=0.5
    PH=8.2
    CYA=33
    TA=150
    It seems I keep adding 0.4 gallons of bleach everyday (using bleachCalc!). Should I raise the cya higher?
    Thanks in advance.
    btw to the Texas posters...I'm actually in Round Rock also!!!! small world.
    Centexpool
    16x48 Above ground Intex, with 130 lb Dougboy sand filter 3/4 hp pump.
    6031 gallons
    SWG
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    You are going to have to add bleach everyday anyway, so you are fine. You need to lower your pH with muriatic acid though.
    When do you add your bleach? It's best to add it in the evening, so it can work at night when it will not be degraded by the sun.
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
