Thread: A&A Pop Up Problem
    Sep 2012
    Buckeye, AZ
    10
    A&A Pop Up Problem
    I have 1 pop up when the head is in, the gear set stops at that location. When I remove the head the gear set moves and all is ok. I have replaced the gear set - no change. New heads still stops. This is an A&A top flow 5 port with balls. I have removed other heads and blew out small scale chunks..not sure whats left. I have moved the balls around and still stops at same spot..There is no valve or flow restricter on the top flow port. All powered by just pool filter motor..worked fine before for 4 years..
    Any ideas?? Thanks
    22,553
    Re: A&A Pop Up Problem
    Sounds like a tooth missing in that one spot on the gears and when the head is in it causes enough resistance to stop the gears. Have you inspected all the gears?
    Sep 2012
    Buckeye, AZ
    10
    replaced the whole set
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Did you just replace the gear set or the balls as well? I'm not that familiar with the details of how the ball-type valves work, since they all have the flip-type valves now.
    Sep 2012
    Buckeye, AZ
    10
    replaced all but balls, cant get em anymore but the cam on the gear set is new as well. would have to retro the new valves with glue..that concerns me a bit
