Results 1 to 10 of 10
Thread: Cutting solar cover into strips support thread!
    Jul 2012
    Chicago, IL
    358
    So, I've finally gotten a solar cover and while it isn't all that difficult to handle, I could see how cutting into strips would make it much easier. I believe I've read of others doing this... is there any downside? Do the strips stay pretty well in place, i.e. they do not tend to overlap and leave large sections uncovered?
    I'm thinking of doing it in three sections along the seems that already exist, does this sound like the best way?
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: Cutting solar cover into strips support thread!
    Pauls,
    Here's a thread that might help. http://www.troublefreepool.com/cutti...ns-t44453.html
    And this offsite link has lots of good pictures http://www.ellerbach.com/Pool/Solarcover/
    I plan to do it once I get a solar cover.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Jul 2011
    Mesa Arizona
    190
    I thought about that but that was far too much of a pain to remove and replace so I just got a solar reel. Simple and VERY effective. Rolls on, rolls off in seconds.
    I found a nice solar cover reel on Craigslist for $60.00.
    Mesa Arizona. Old school 26,000 gallon in ground plaster pool with sand filter built in 1984.
    mas985's Avatar
    Pleasanton, CA
    11,742
    I did something that is a variant of the SolarRoller. I cut the cover in half but I attached each half to 1.5" ABS pipe (ABS floats). So now I just twist the pipe and the cover rolls up on itself and I can pull it out fairly easily. The Solar Roller works fairly well too except it uses aluminum pipe which corrodes quickly in the salt water.
    Mark
    Oct 2007
    Valrico, FL
    542
    I did something similiar. I used 1" PVC pipe filled it with polyureathane foam. Works great!
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I was thinking of PVC capped at both ends, but now thinking PVC with a noodle in it. Or possibly ABS, have to look at what I have on hand and cost of parts that I don't have.
    Dan D
    mas985's Avatar
    Pleasanton, CA
    11,742
    ABS is the lightest and will float so you don't need to cap it or fill it with foam. Also, it will drain easier without caps and foam.
    Mark
    Jul 2012
    Chicago, IL
    358
    Thanks, good ideas here. The pool has a deck around maybe 20% of it so a solar reel isn't a good option unfortunately given that I do not want it to cut into the swimming area. The ABS pipe sounds good, do you simply drop the pipe in the water and start turning? I am thinking of building a hook system off the back of deck (out of site) to put the cover in when not in use and I think this would facilitate that.
    There is a picture of my set up in this thread in case that might help:
    would-like-a-modest-increase-in-water-temp-t51695.html
    mas985's Avatar
    Pleasanton, CA
    11,742
    You need to attach the cover to the pipe. I use the same clips that the solar roller uses and you can buy them separately. I drill a small hole in the pipe with a notch and use the plastic clips shown here:
    http://solarfactory.com/parts.html?page ... gory_id=10
    Mark
    Northern Philly Burbs
    60
    I've done the same thing with PVC pipe and I tired of it very quickly. I cut it up in thirds. My wife, inlaws, babysitter and kids never got the hang of it. I went to a reel and my 5 year old can now cover and uncover the pool.
    25000 gal inground freeform plaster pool with spillover hot tub. 1.5 hp PacFab Challenger pump, Hayward DE filter, Natural Gas heater, BBB convert 2009, Aquasol solar panels on ground rack 2010, PS-4 controller 2010, Rocky roller, SWG 2011.
