Thread: HELP PLEASE with a Perfectemp heater
    Jun 2012
    St Pete FL
    45
    I am taking care of a pool for a guy who lives out of state. The heater does not seem to work correctly. At first it was because the water bypass was turned off. Now that the water is running thru it turns on but then temp seems to be the same. Turned the pump on yesterday it ran it's normal 6 hours, 10 am -4pm, went back today and temp was the same as when I left yesterday. Is it possible it cooled down that much after the pump stopped running? Outside temp is 86-92 , the pool temp is cooler than the outside air temp. The pool is 15,000-20,000 in a screened in area that does not get alot of direct sun. When it does run there is cool air coming out of the top where the fan blows. I can hear water circulating thru it.
    The heater is a Perfectemp model HP-6 not sure how old it is.
    I am going back now to switch it to the spa and see if that will heat up since it is a smaller area. If that doesn't work what is next???
    Thanks
    5,000 gal Fiberglass paper cartridge filter, autochlorinator, BBB
    20,000 gal Pebble Tec paper cartridge filter, BBB
    15,000 gal Pebble Tec, DE filter, autochlorinator, BBB
    20,000 gal Pebble Tec, sand filter, BBB
    Jun 2012
    western NY
    1,560
    Re: Perfectemp heater
    If there is no heat coming out of the exhaust then it is not lighting. Could be any number of things. Is the Gas turned on? The power seems to be on as you can feel air coming out the exhaust.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2012
    St Pete FL
    45
    No the gas is not turned on because there is no gas. It is electric.
    Jun 2012
    western NY
    1,560
    Quote Originally Posted by lilpam14
    Ahh, OK, so is it a heat pump or a resistive element heater? I will assume heat pump, as it has a fan that blows out the top.
    Jun 2012
    St Pete FL
    45
    Yes it is. The way I understand it, it works along the same principal as an a/c unit. Only heats rather than cools, hence the cool air coming out of the top fan area. I switched it last night to only heat the spa and put in a thermometer. Went back this AM after it had ran for 14 hours with no temp. change. Any ideas or suggestions now???
    I would post a picture of what I am dealing with but cannot figure out how to do that.
    Jun 2012
    St Pete FL
    45
    Re: HELP PLEASE with a Perfectemp heater
    Had to bite the bullet and get someone out to look at it. It ended up being the capacitor.
    Oh well I probably could have never fixed it.
