Thread: Need to add salt.
    Jojo4A's Avatar
    Jun 2012
    Moundville, Alabama
    37
    Need to add salt.
    We have had a lot of rain here in West Alabama. Did my full testing and my salt reading is 2600ppm, with a goal of 3000. According to Pool Calculator, I need to add 54 pounds of salt. Couple of questions. 1. I know I need to add salt specifically for pools, I read somewhere it was ok to use the same salt that is used in water softening systems. Is that correct? 2. Do I just dump the salt in the pool?
    FC 3.5
    CC 0
    pH 7.5
    TA 70
    CH 120
    CYA 70
    Salt 2600
    Joanne
    West Alabama -18x36 Grecian Sport, IG Vinyl, 3.5 - 5.5 - 3.5. ~16000 gal
    SWG. T-100 Test Kit. Taylor Salt Water Test Kit, Taylor Speedstir.
    Pentair SD-80, Pentair Superflow 1HP, PentairIntellichlor, Polaris 280
    38,279
    Re: Need to add salt.
    I use the Solar Salt from the hardware stores ... about 60% of the cost of the "pool" salt. The pool salt is just ground up a little more so it dissolves faster. The solar salt still dissolves in a matter of minutes. Just dump it in and brush it around.
    You do not want any salt that has any additives (rust inhibitors, etc).
    Aug 2010
    Dallas, TX
    4,052
    Same here, the Diamond Solar Salt from the hardware store. Super cheap.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    I've used pool salt from Walmart and water softener salt (the one that is only salt..blue bag?). Salt is salt, right?
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Sep 2009
    Greentown, IN
    914
    Blue bag almost anywhere you go... watch the amounts.. sometimes the sizes of the bags vary a bit. I just scatter it around the pool and it dissolves pretty quickly with the pump running.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Jun 2011
    Long Beach, CA
    2,784
    When ever you add salt to the pool make sure the SWG is turned off for a day. You don't want the cell get exposed to a high amount of salt at any time. Just add bleach for a day while the SWG is off.
