Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: New Build and Upgrades - Dallas, TX
    Will try to keep it short. Have been lurking for a long time and posting on another site. This one seems to have more action.....so here it goes!
    Original Estimate:
    Dallas, Texas
    Pool/Spa
    Surface Sq ft: 450
    Perimeter: 90
    Pool Size: 30' x 15' (straight line)
    Depth: 3.5'-5'-4' (sport)
    16,031 Gallons
    Gunite
    1 bench, 1 sun deck
    Filter: Jandy 48 sq ft DE filter
    Circulation Pump: Stealth Pump 2 hp
    Chlorine Dispenser: Rainbow 320
    Computer Center: Jandy PDA PS4 (pool/spa)
    Heater Size and Electronic Ignition: Jandy LRZ400 Natural Heater
    Cleaning System: Polaris 280
    Spa: 8 Jets, 1 fountain, Polaris 220V 1.5HP QT blower included
    2 skimmers, 5 returns, 2 safety main drains
    1 500W pool light, 1 100W spa light
    Coping: OK Flagstone
    Estimate: 40k
    We upgraded to SWCG and switched to Tennessee Flagstone. Also changed to a 2 speed pump.
    Took it to just under 43K.
    I've now asked the PB if we should look at LED's and extending the Tenn Flag coping from 12" to 18" - the pool is surrounded by grass with no decking except the front.
    He said the LED's are pretty nice, but only I would know if it was worth the nearly 2k upgrade for 3 of them (1 spa, 2 pool).
    He also said to go from the 12" to 18" would cost an extra $1,400, but he didn't comment on wether he thought it was necessary.
    What are your thoughts? Are LED's worth it and should I switch to the 18" coping?
    Here is a youtube render of the pool so you can see layout and yard. The mountains in the 3d render are MUCH nicer than the mountains in my backyard here in Dallas Texas!
    [youtube:2sfg9cen]J_LcLcYW3JU[/youtube:2sfg9cen]
    Thanks for any and all advice!
    15x32 16k Gal IG riversand (pebblesheen) pool, Filter: Jandy 48 sq ft DE filter, Circulation Pump: Stealth Pump 2 hp 2 speed, SWCG, Heater Size and Electronic Ignition: Jandy LRZ400 Natural Heater, Cleaning System: Polaris 280, Spa: 8 Jets, 1 fountain, Polaris 220V 1.5HP QT blower
    Aug 2010
    Dallas, TX
    4,052
    Re: New Build and Upgrades - Dallas, TX
    Um, we have no mountains!
    So, no Rainbow chlorine dispenser, only the SWG, right?
    Is the heater just for the spa? We don't have a heater on our pool, and don't desire to have one.
    Not sure if they are removing the Rainbow or not. Will ask. I know they need to chlorinate the pool for the first month before turning on the SWG but I assume floaters would do the job.
    Heater is for both spa and pool.
    Aug 2010
    Dallas, TX
    4,052
    Floaters are good at first, as long as a bunch of stabilizer isn't added at the very beginning. You'll be shooting for CYA of 70-80 when you are up and running.
    Any thoughts on the coping and LED lights? Or not sure....
    smccull's Avatar
    Apr 2010
    Allen, TX
    96
    Just let them install the standard incandescent lights and then buy your own LED/color change screw in bulbs and change them yourself - I changed two small and one large for less than a few hundred bucks
    Steve
    Deep in the Heart......errrr HEAT of Texas
    20k gallon gunite formal
    smccull's Avatar
    Apr 2010
    Allen, TX
    96
    http://m.poolsupplyworld.com/viewall/vi ... tbulbs.htm
    Large bulb is $278 and spa size are $125 each - I love ours, been in pool for two seasons and I run them several hours a night.
    Can't comment too much on coping - we have one of three sides that is all grass but nobody ever walks back there
    Steve
    partypond's Avatar
    Jul 2008
    Frisco, Texas
    89
    I would say yes to the flagstone. About 1/3 of our pool does not have deck up to the coping and we did about 18 in of small stones with flagstone pavers so there is a path around the pool. I would not want grass real close to the pool edge just so when you mow you don't get alot of clippings into the pool. We have the LED color lights and really like then color shows!!
    PS - wish i could find that mountain view too!
    36x16 gunite, 14,500 gallons, Jandy 2.0hp VS Epump, Jandy CL460 filter, Automatic chlorinator, Jandy Legacy 400K BTU Heater, Polaris 1.5HP spa blower, 2 Colorlogic pools lights and 1 Colorlogic spa light, Polaris 3/4HP booster pump, Polaris 280 cleaner, Jandy PS4 with PDA, QuartzScapes Montego Bay plaster, OK flagstone coping, spray deck (aggregate effect) - completed 3/2011
    Oops....just saw this should be probably be in the "under construction" section..... Darn newbies.
    I have also asked about stepping stones around the coping to see price difference.
    Thanks!
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I will say that either 12" or 18" is not very much space! You're going to get a lot of grass blown into the pool when you mow. I wouldn't want to edge around those square pavers!!
    The nice thing about the expensive LED lights is that they can be synchronized and different light shows displayed.
    Looks great! I had 5 PB bids, and every bid included some kind of decking around the perimeter of the pool. Grass that close might be an issue like partypond said.
    I would absolutely do the LED lights. They are beautiful at night...
    It looks great! Good luck!
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
    I'm not worried about edging around the pavers, that's my wife's problem.............. JUST KIDDING.
    Our yard isn't the biggest and we wanted to keep as much grass as we could. I guess if its a problem, we could always add decking later.
    I assume clippings in the pool is more of a negative cuz it just means more cleaning, correct?
    Mar 2011
    Houston, Texas
    413
    My pool is somewhat similar to yours in design. We ended up going with travertine coping because we were concerned that the salt could damage the flagstone that we originally planned to use. It all depends on how soft your flagstone is--I've had friends who have had horrible experiences with flagstone and salt. Our travertine was way more expensive, but it looks great and seems much harder than flagstone. We also sealed it well and after about 18 months with the SWCG I've seen no damage to the travertine.
    Grass does surround about half of my pool (up to the coping) and each week I spend a few minutes cleaning grass out of my pool. Not a huge problem, but just expect it.
    Also, I originally had the Rainbow 320 feeder, but I removed it when I installed the SWCG. I probably should have left it attached in case I ever needed to use pucks on a short term basis. With the normal amount of rain we've had this year I've had to top up my CYA several times so using pucks on occasion, at least in my case, would not be a problem.
    Finally, I wish I had a two speed 2 HP pump. I need the higher HP for my spa and water feature, but we don't use them very often. Lower speed would work just fine most of the time and it would save money on electricity.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    Thanks for all the comments!
    Houtex, the builder encouraged us to switch from OK flag to Tenn flag for that reason. Will seal it too!
    Is your coping 12 or 18 inches?
    Mar 2011
    Houston, Texas
    413
    It's 18 inches.
    You think that 6 inch difference make a difference with grass clippings, or probably not?
    Mar 2011
    Houston, Texas
    413
    I measured it and it's exactly 14 inches. I can't imagine an extra 4 inches of coping would significantly reduce the amount of grass clippings you'll get into the pool A few feet of decking would help.
    Oct 2009
    3,899
    I think 12" would be pretty narrow. It wouldn't be wide enough to walk on when using a leaf net or vacuuming, and you might end up with worn-down spots in the grass. 18" is still pretty narrow, but might mitigate some of that. Typically decking is at least 3' for that reason.
    May 2012
    Boyd, Texas
    93
    Quote Originally Posted by bumdaddy
    I don't see the extra 6 inches helping with grass clippings but it would make it easier to walk around the pool. 12" is a pretty narrow path.
    6500 gal, Intex 18'x48" above ground, 1hp Pro Sand Filter, TF100 Test Kit
  20. Back To Top    #20
    Aug 2010
    Dallas, TX
    4,052
    It won't make a difference. I have a large deck and wide tile work around my pool and the clippings still get in. And, I have a raised coping with a slot between the deck and coping, so you'd think that would catch it all, but no.
