Thread: Need suggestions for a new Pump for Inground pool
    Hi,
    The original Hayward Superpump in my pool has a cracked case and a slight leak when under pressure. I'm hoping
    to get some recommendations from folks on the board for a replacement. My thought is to replace it before closing
    the pool this year so its set to go in the spring.
    Here are my specs:
    Location Central NJ.
    23,000 Gallon Inground Vinyl Pool
    Leaky Hayward Superpump with 1.5 HP 230 Volt motor
    2 incoming lines (1 skimmer, 1 main drain)
    Triton II model 60 filter
    1 1/2 inch plumbing
    Stayrite Pool Heater
    Hayward inline automatic clorinator after heater.
    3 Return lines (1 was converted from the automatic cleaner that I no longer use)
    Any help on sizing and where to purchase is greatly appreciated.
    12 X 24 Oval Pool, AG, Vinyl, 52" inch deep
    Sand Filter, 1 HP motor Waterway Model ?? OF flowrate
    38,521
    Re: Need suggestions for a new Pump for Inground pool
    What do you use for a cleaner?
    Any water features?
    Solar?
    Given just what you have written a 1HP is likely plenty ... even 3/4HP is probably sufficient given that you did not list any high flow rate requirements.
    A 2-speed would also save you more money on electricity by running on low most of the time.
    Since you have 230V at the motor ... the 1HP 2-speed Superflo might work well for you.
    Nov 2011
    Moberly,MO
    1,010
    Just replace the case.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Jason,
    For a cleaner, I use the old fashion manual vacuum (me...). No water features or solar, Just the Stayrite gas pool heater.
    Thanks for your suggestions.
    22,553
    I aggree with JB, a 1hp 2-speed Superflo would be a good replacement.
