Thread: FAS-DPD CC Test Only Possible?
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Hi all, I have a Palintest 7100 Photometer, which includes a Chlorine DPD-HR (High Range) Test (for TC to 250ppm,) is testing for CC only with a FAS-DPD Palintest SP-400 Oxystop possible or is it necessary to test FC first? The Palintest SP-400 has powder, DPD Reagent, Oxystop Re-agent and DPD No3 Reagent.
    If I could do the CC test using the FAS-DPD only, then I could go ahead and get the reagents for the TC HR Test on the photometer, which would work out cheaper (and faster) than using drop reagent when pools are at Chlorine levels above the normal DPD range of 0-5ppm
    Regards
    Stuart
    Stuart Murray
    Scotland UK
    UK NPPOC
    38,290
    Re: FAS-DPD CC Test Only Possible?
    While some of the names you listed I am not familiar with (Oxystop, etc), I am pretty sure that you have to test the FC before the CC with the FAS-DPD test.
    Just try it and see if the two results match.
    18K Gals, Intelliflo VSD, Pentair Catridge, SWG, Solar & Gas Heat, Pebble Tec, Jandy AquaLinks, Pool Pal for Android.
    30,421
    Using the FAS/DPD test, it is not possible to get a CC result without first getting an FC result.
