Thread: Initial water readings looking for verification
    Hello,
    Long time lurker, finally upgraded from a 12' to 18' x 48" Intex (pictures and blog to follow - It was A LOT of work but worth it so far). Got my baseline numbers from my tap water and I am a little concerned about the CH. As well wanted to get someone to look at the numbers to see if anything seem out of line.
    PH 8.6 = Add 72oz of Muriatic acid
    FC .5 = Add 42oz Bleach
    CC 1
    TC 1.5
    TA 350
    CYA Under 20 = Add 113 of stabilizer
    CH 300 = Says to add water (this is already out of my tap?!)
    Pool estimated @ 5455 Gallons water temp ~83, Will be utilizing SWG for chlorination.
    Again much help reading these forums and looking forward to the comments.
    18' x 48" Intex, 2650 Intex Sand filter/pump
    22,550
    Re: Initial water readings looking for verification
    I get completely different amounts to add.
    At 5500 gals
    pH 8.6 to 7.5 = 41oz of MA
    FC .5 to 3 = 29oz of bleach
    CC 1 = Shock
    TA 350 = Areation and acid to bring it down. You don't need to be in a hurry about this.
    CYA 15 to 30 = 11oz of Stabilizer. You can wait till after you finish shocking to add any if you'd like.
    CH 300 = Nothing. If this is coming out of your tap there's not a lot you can do about it. At 300 I wouldn't worry about it too much.
    Bama,
    Thank you very much for the verification and assistance. I love the helpfulness of this forum!!!!
