Results 1 to 16 of 16
Thread: Borax vs Boric acid
    Melbourne, Australia
    74
    Borax vs Boric acid
    I have found a supplier that supplies borax and boric acid in bulk and very cheap.
    They are the same price for a 25kg bag.
    Boric acid seems to me superior to borax....
    Am I right?
    13,000 gallon; sand filter; inground; fibreglass; pump not sure yet (need to check); Installed over 12 months ago.
    Bluegrassman's Avatar
    Jan 2012
    West KY
    243
    Re: Borax vs Boric acid
    the advantage of using boric acid rather than borax would be not having to counter-balance it with muriatic acid addition (due to pH), as well as taking less product to achieve your desired borate level.
    18x36 Vinyl IG ~27,000 gal, Intelliflo VF Pump, 300# Sand Filter, Polaris 280 w/Pentair Booster Pump, Pentair EasyTouch w/ IC40 SWCG
    TF100 Test Kit
    SpeedStir
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Yeap Boric acid is a bit easier to use.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Can you post up some info on the supplier - and cost?
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Jul 2012
    Chicago, IL
    356
    Quote Originally Posted by Bluegrassman
    Why would you need to counter-balance? Aren't you adding borax specifically to up the pH? I've been using the BBB but to this point I have only had to use bleach. My pH dropped a bit recently though so I am about to add borax to up it per the pool calculator. Am I missing another variable?
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    Jun 2012
    Howell, NJ
    977
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Aug 2010
    Dallas, TX
    4,052
    I got my boric acid here:
    http://www.dudadiesel.com/search.php?query=boric
    Any of them will work, just get the cheapest for the volume you need. I used the granular, and it still dissolved very fast.
    For a pool the size of mine, it was MUCH easier.
    I tried the Borax route, this got me halfway there.
    74
    Sorry no-mas - I am in Melbourne Australia so a bit too far from FL!!!
    But just so that you know it is $50 for 25kg which is basically in your money, $50 for 110 pounds, I think.
    Not sure if that is cheap or not but we don't have 20 mule over here and don't really have big stores that sell bulk over here either....
    I also like the idea of buying a 110 pound sack of the stuff and being done with it.
    I think 110 pounds of boric acid should last a long time?
    Jan 2012
    West KY
    243
    Juzzie, it will take a little over 22 lbs of boric acid to bring your pool borate level to 30ppm, so yes, I think 110 lb will last quite a while
    I plan to add borates to our pool next year. If I can find a decent deal like yours, I will certianly go the boric acid route as well.
    TF100 Test Kit
    SpeedStir
    74
    Oops just realised I think 25 kgs is 55 lb.
    Must remember not to do maths when drinking beer. Especially when posting results up on forums!
    Jan 2012
    West KY
    243
    Quote Originally Posted by juzzie
    right you are! I saw 110lb and didn't give it a thought myself, lol
    TF100 Test Kit
    SpeedStir
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    ??? When I used Pool Calculator and put 0 ppm in current and 30 in the goal and set the volume to 15800 I got over 24lbs. It's a small difference but I am curious how you calculated the 22lbs above.
    Mar 2007
    San Rafael, CA USA
    12,082
    Use 15850 gallons in The Pool Calculator and put in 0 for Now and 30 for Target in the Borate section and select "boric acid" and I get 363 ounces by weight which is 22.7 pounds.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    If the OP is using borax to raise pH, it must be borax. Boric acid doesn't do that. If you are looking for a bit of algaecide protection, better water feel and pH buffering, either will do, but borax will require lots of acid to rebalance the pH, whereas boric acid won't affect the pH.
    Corrected
    chiefwej
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Quote Originally Posted by chiefwej
    If the OP is using borax to lower pH, it must be borax.
    Borax raises pH. Hence the need for MA to bring it back down after adding borates.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by chem geek
    DOH! I see what I did. I was looking in the wrong blank. The one I looked at was VOLUME not WEIGHT! Ounces can be a confusing measurement for that very reason.
