Thread: How often to test borate level with lamotte borate strips?
    Melbourne, Australia
    74
    I am going to order some lamotte borate strips.
    How often is normal to test?
    13,000 gallon; sand filter; inground; fibreglass; pump not sure yet (need to check); Installed over 12 months ago.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: How often to test borate level with lamotte borate strip
    Once you have borates at the desired level you only need to test when you have had an exchange of water (either by draining and refilling or water dilution from heavy rains) or on closing and opening the pool.
    Love TFP? Become a
    TFP Supporter!
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    In peak season I originally tested weekly, but found that fairly unnecessary. It kind of depends on splash out and dilution. I suspect you'd be fine testing every second week or even every month. Since both cya and borates stay in the water, it makes sense to test them on the same schedule.
    Oops, cross-posted. What zea said.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
