Thread: Pool pump - Jacuzzi Magnum Force auto shut off?
    Jun 2012
    Barrie, Ontario, Canada
    28
    Hi everyone,
    Does anyone know if this pump, or all pumps have an auto shut off if the pump ever stops getting water? Or it has some sort of technique where it will not burn itself out?
    I am just curious because we have a tree in our backyard and lots of leaves on it and they are starting to shed, and if the leaves ever build up enough in the skimmer, even overnight while it is running or when no one is home, will the pump shut off? or overheat so it shuts off?
    Thanks
    Size - 50,000 Litres / 13,208 g (32' x 16' x 4.5' Sport Pool)
    Filter - Jandy CL460 Cartridge Filter
    Salt Water - Zodiak LM2
    Pump - Jacuzzi Magnum Force
    Heater - Laars LT LT250NS-C
    IG Pool (Vinyl)
    2003-2005 ish
    38,251
    Re: Pool pump - Jacuzzi Magnum Force auto shut off?
    most only have a shut off feature if the motor overheats ... that may not happen if the pump ran dry and you would still get pump damage.
    Some of the newer pumps with suction sensors (SRV?) Would actually shut off.
    Posted from my Droid with Tapatalk ... sorry if my response is short
