Thread: above ground plumbing turning white
    jeffreymlewis's Avatar
    Jul 2012
    Walnut Creek, CA, USA
    7
    Today I began replacing stickers on my above ground plumbing. I decided to scrape off the old stickers (and adhesive residue) with a putty knife. After repeated scraping, the pipes started turning white (see attached picture). That is, I seem to have begun scraping off the black coating from my pipes.
    Is this a sign of trouble? If so, what can I do (short of replacing the pipe)?
    Is it safe to use ammonia-based cleaners (aka Windex) on these pipes?
    Jeffrey
    15k gal, IG painted plaster (black), 3.0 HP Intelliflo VS, Pentair CCP240, MiniMax 400, build date unknown (estimate 1995), attached spa w/ water fall
    38,271
    Re: above ground plumbing turning white
    Welcome
    All the PVC plumbing started off white (there are some black ... but rare). After install, the builders painted it to try to protect it from the sun's UV rays.
    You did not hurt anything ... just buy a can of spray paint
    Feb 2008
    Denton, TX
    5,061
    Good advice from jblizzle. Welcome to TFP!
