Results 1 to 9 of 9
Thread: Help My Pump Had a Premature Death
    Sep 2012
    Atlanta, GA
    5
    I just bought my house a year ago in June. The pump (Pentair Superflo 2 hp) was replaced in May of 2011, right before I bought the house. It has already failed, it just kept getting louder and louder of the last few months. I cannot understand what happened to the pump. It's on a timer, and I was running it approximately 10 hours a day. I followed the previuos owner's instructions and the pool has been great all this time. At any rate, I am not at all handy and am going to replace it this week. My question is what size do I need? I am at 2hp now. With the solar panels and all, do I need a bigger one, could I get by with a lower HP or should it stay the same? Also, I am considering going with the Whisperflo iinstead of the Superflo. Has anyone done that? Thanks in advance. I am so happy I found this forum.
    36,000 Gallons, - Sand Filter (3.1 and 60GPM), IG, Vinyl, Pentair Superflo 2HP, 15-20 years old, Solar Heated by Roof Panels, Polarus Cleaner (no booster)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Help My Pump Had a Premature Death
    Welcome to tfp, ttiger2012
    A single speed 2 hp super pump may be large for your pool...but it is certainly large for your filter (assuming the 3.1 you posted in your sig refers to the filter square footage).
    Do you have any water features that require that much flow rate...i.e. waterfalls, spa jets, in floor cleaners?
    If not, then a 1 hp [s:17ydbybp]superpump[/s:17ydbybp] superflo (or equivalent) may be a better size fit.
    Another option you might want to consider is replacing just the motor with a 2-speed motor. The advantage might be saving some money compared to a new pump, and being able to run on low speed to save energy and filter better. Since you mentioned, that you are not handy, this would probably be best done by a pool store.
    You say the pump is becoming more noisy...can you describe that?
    Sep 2012
    Atlanta, GA
    5
    Thank you for the quick reply. I am running a Polaris cleaner, and my solar heater but no other equipment. When I say loud I mean it is dragging along and sounding extremely loud, like it's dying. It seems like it is hardly doing anything to the water now. My brominator has been leaking some and I think that has been affecting it too. I just ordered a new o-ring for the top. I shut the pump off today because it sounds like it is on it's last leg.
    Sep 2012
    Atlanta, GA
    5
    Also, my neighbor is going to replace the pump for me. I could get just a motor I guess, but not sure what 2-speed motor I would purchase for the Pentair Superflo that would be compatible. I can research that. Any ideas where to start? I am trying to get something ordered because the water is looking pretty bad at this point.
    38,405
    Is the noise from the motor (bearings) or the pump (wet end)? Have you checked to see if there is anything clogging up the impeller? Getting just a motor would certainly be the cheapest route. Is your current motor 115V or 230V?
    I have the 1HP Superflo and will be using solar ... there is another member who has solar with a 3/4HP pump. Not sure what the cleaner requires as far as flow rate though.
    BTW, if you go with a smaller motor, you will also have to get a smaller impeller.
    Sep 2012
    Atlanta, GA
    5
    The noise is definitely coming from the motor end. I am going to look up the flow for the Polaris. I think I have the manual for it. I will have to check on the 115 vs 230. I feel so backwards. Have never had to deal with this before but am learning lots.
    Sep 2012
    Atlanta, GA
    5
    Okay a little more info. The filter is a Pentair Tagelus sand filter with a 3.1 filter area and a 60 GPM flow rate.
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by ttiger2012
    I think it likely that your 2 HP pump is too large for the filter (and probably the plumbing; it's probably 1.5 ", with one skimmer, one main drain and two returns). Consider going to a smaller pump, or possibly a two-speed.
    The superflo's are good, the whisperflo's are better (many would argue that they are the best).
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    38,405
    Quote Originally Posted by Qwaxalot
    Although the Whisperflo may still be larger than you need (depending on your current wiring for the pump motor).
