Results 1 to 10 of 10
Thread: Closing a baquacil pool plan to convert to chlorine.
    Aberdeen, New Jersey
    12
    Is there anything i should or should not do while closing my 30000 gal ig pool? I plan on opening it with chlorine next season.
    Thanks for any info.
    30000 gal rectangular inground pool
    TF-100 test kit, Vinyl Liner
    hayward c4030 cartridge filter.1 hp Hayward SuperPump SP2607X10
    Aquabot Turbo cleaner + Dolphin Supreme MX5
    Solar- Breeze robotic skimmer
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,112
    Re: Closing a baquacil pool plan to convert to chlorine.
    I myself would just cover it and forget it. You're gonna fight green water no matter what next year, so why spend the cash on chemicals at the end of this year.
    Nov 2011
    Moberly,MO
    1,010
    Before closing get a baquacil remover and circulate it for a few days thriugh the filter system.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    12
    Quote Originally Posted by swimcmp
    Will a baquacil remover work without adding chlorine?
    Nov 2011
    Moberly,MO
    1,010
    Yes that is the purpose of the remover, to eliminate the traces of baquacil. You just want to put it in a couple of days prior to closing. This will make opening easier. You will want to do this before putting chlorine in it.
    38,537
    I think this is the first time I have seen a "remover" mentioned. Chlorine will do the same thing by breaking down whatever Baq is still in the water. Not sure how the cost of the remover vs. more chlorine pans out.
    30,432
    While I certainly am not a baqua expert, I think it will diminish on it's own...particularly over the winter and, as Jason says, chlorine will get it anyway.
    Jul 2011
    Eastern Ohio
    7,112
    I've never heard of a Baquacil "remover". Any links to this product???? The only thing I've seen suggested by the manufacture of Baquacil is to use "Pool Breeze(tm) Non-Chlorine Shock Treatment".
    http://www.poolsolutions.com/gd/conv...-chlorine.html
    I plan on doing the same thing, converting next Spring...was wondering if I should put any Baqua chemicals before closing this season. Thanks!
    38,537
    I do not think there is any point in putting any chemicals in the pool before closing if you are converting in the spring. You are going to have a mess to deal with either way ... save the money for bleach in the spring.
    EDIT: Although ... as this post suggests (closing-a-baq-pool-t52246.html) ... maybe it would be better to add some chems to avoid fighting algae and baq in the spring. Maybe I will crawl back in my hole since I have no idea what I am talking about
