Results 1 to 7 of 7
Thread: Impurities in Bleach - should I worry about it?
    Broken Arrow, OK
    24
    I am a newbie to pools. I have read up on the BBB method and am excited to use it. I was talking with my hubby yesterday about all that I have learned and he was concerned about the impurities in cheaper bleaches. He said he had heard of lots of iron in cheaper bleaches. Is this something I should worry about? Right now, I am purchasing Aldi's bleach, which says it is 6% sodium hypochlorite. Thanks.
    Michiele
    Newbie pool owner
    25,000 gallon inground, vinyl lined pool, sand filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Impurities in Bleach - should I worry about it?
    Quote Originally Posted by michiele
    Bleach is sodium hypochlorite, water and sodium hydroxide (lye). There is nothing in the manufacturing process that would add anything else. The process is performed by running an electrical current through salt water, just like a SWCG does in the pool.
    I have also heard the claim (from a pool dealer ) that there is lots of iron in bleach however I cannot substantiate it it. Clorox make no mention of it nor do any of the others I found the MSDS sheets on. Logic tells me it is probably B.S. since iron would hinder the bleaching ability of the product. In other words, it wouldn't get the clothes as white.
    Dave
    Broken Arrow, OK
    24
    Thanks for the input. I will reassure my husband on this.
    Michiele
    Newbie pool owner
    gonefishin's Avatar
    Joliet, Il.
    413
    Hi michiele welcome to the forum!
    Where did you hear this bit of information? Generic bleach is the same as other bleach...sodium hypochlorite. If you can find any plain bleach on sale...buy it You just need to make sure that the percentage is 5.25 instead of the lower 3% that you find once in a while.
    dan
    33' Aqua-Leader AGP
    Hayward cartridge filter and IntelliFlo VS pump.
    Solar Heat coming ; used to own Aqua-Cal HeatWave 100k (HeatPump)
    Aqua-Rite t-15 SWG
    Mar 2007
    San Rafael, CA USA
    12,082
    Technically, having metals in bleach or in chlorinating liquid is a potential problem, but is easily mitigated during the manufacturing process. This is talked about at this link and this link. Metals and other contamination can be introduced via the water that is used (if it's not filtered through a water softener or demineralizer) or the type of salt that is used (if mined rather than evaporated). Clorox makes a good product so buying a quality chlorinating liquid or Clorox bleach should be fine. As for the "cheap" bleaches, it is possible for them not to be made as well. If they do not filter their water to remove metal contaminants before processing, then the final product will not only introduce metals, but will likely have the chlorine level be very low as the chlorine will degrade rapidly in the presence of such substances.
    In some cases, you get what you pay for. If someone is concerned, then the safe thing to do would be to take some bleach, dilute it with known clean water (distilled or filtered), remove the chlorine via thiosulfate or equivalent, then test for metals. Also, if the chlorine level measures as stated at around 6% (or 5.25% depending on brand), then it is likely to be of higher quality. If it's not stated and measures at 3% or so, then there may be contamination.
    Quote Originally Posted by chem geek
    ...if the chlorine level measures as stated at around 6% (or 5.25% depending on brand), then it is likely to be of higher quality. If it's not stated and measures at 3% or so, then there may be contamination.
    Excellent observation Richard as usual.
    Dave
