Results 1 to 17 of 17
Thread: How many lower the water level for winter?
    linda1's Avatar
    Mar 2010
    Western Pa.
    298
    Or do you leave it and plug skimmer and return? We have very harsh winters and the past two winters I have lowered the water 6 inches below the return. I know I've read that some people leave the water level and I am very tempted to try this approach but nervous that the ice might damage things. Would love the hear what works for you in an area that gets severe winters.
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
    Jun 2012
    Howell, NJ
    977
    Re: How many lower the water level for winter?
    I've had the pool for 6 (or was it 7?) years, and I have never lowered the water. In fact, (and I know no one is going to like what I say), I even pump the water off the cover into the pool. We run it through a filter first. My well water has a lot of iron, so this is really the only option, aside from sequestrant. Every year when I open the pool, it has been fine, except for leaves and lots of dirt on the bottom. I can't recommend this method, because everyone's pool is different, but all I can say is that it works for me.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    30,419
    The climate is quite different in NJ than in Western PA. My climate is even more different. If I lived in Westren PA, I would lower the water below the returns religiously. The damage from freezing is real and that's why people do it.
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    I am in Southeast PA, I lower my water level. I did not lower it one year and water froze in the skimmer. The skimmer cracked and needed replacing and it also dented the wall of the pool where the skimmer is located.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    Nov 2011
    Moberly,MO
    1,010
    We are in central Missouri and have just recently started using skimmer plug and putting a return plug in the returns and have had good luck the last two years doing this. Although last winter was really mild for us. We drain the water out of the pump, filter and all plumbing. This has seemed to help with keeping winter covers on as we have less pull on them since pools remain mostly full. Hope this helps
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    We drain here in Minnesota...we freeze up solid.
    Imo, not worth the risk to not drain if you have a potential for freezing.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Northern Ontario, cold winters and a lot of snow, I lowered mine last year (by more than 6 inches) and I'll do it again. I don't want snow/ice getting in the return or the skimmer, it will wreck them.
    Aug 2009
    SW Wisconsin
    518
    I am in SW Wisconsin...We freeze hard here too, and I drain to about 2 inches below the return (which is even lower on the skimmer)
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Jun 2012
    western NY
    1,560
    18' above ground and live in western NY. Lots of cold and lots of snow. I have an aqua door for the skimmer and a 1.5" plug for the return. I unhook both hoses so no water can stay trapped. I drain the filter and put the pump in the garage. 15+ years this way with no problems
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    I have always drained, but would consider using a skimmer cover if enough people have had good experiences.
    How does the return not get cracked since it would be completely submerged in (frozen) water..?
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Jun 2012
    Howell, NJ
    977
    I guess maybe here in Jersey the water doesn't freeze down to the return. This year I am a little worried though, because the eyeball is loose, and when I plug it to clean the filter, it still leaks. I am afraid that come winter, it will leak and freeze, and then crack. Guess I will just have to wait and see. And I am not sure if not draining is a good idea, it might just be that I have been lucky. Although, it would be at least 6 years of luck. I can't advocate not draining, because every pool is different, and every city is different. If you think there is a risk of freezing, drain. I am sure replacing a cracked skimmer, or fixing something because of a freeze is not better than draining.
    John
    Nov 2011
    Moberly,MO
    1,010
    Speedo you have to use a plug in the return fitting. We always disconnect any plumbing from the skimmer and return so no water can be trapped in the pump or filter. John you are exactly right every location is unique, the best recommendation is talk to a local pool company and see what they recommend for your area. See if they will explain their procedure for closing and go from there.
    linda1's Avatar
    Mar 2010
    Western Pa.
    298
    Guess, I will lower the level like years past and play it safe! Thanks for the feed back.
    Quote Originally Posted by swimcmp
    I should have phrased that better, I meant with the plug, wouldn't the "collar" and plug freeze and crack?
    x2 on playing it safe, probably the best and overall easiest way.
    Aaron
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    I haven't lowered the last 3 or 4 years. I just plug it all up and remove the equipment & hoses. The pump/filter goes in my basement. I'm still on the original liner. I have seen some ice dig marks above the normal water line, I'd rather have that high then under the water line. The only plastic damage was the plastic butterfly nut on my drain plug broke. Whoopee. Mine freezes solid.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Jun 2012
    Indiana
    81
    I posted a topic about a product that would enable me to avoid draining, but no one has responded with info. Could those of you who have survived winters with a full pool specify what you use to plug the openings?
    If AG, do you still need the pillow under the cover?
    Jess :) from southeastern Indiana, USA
    27' x 54" ~17,600gal AG round
    Waterway Ecco 22", 250# oval sand filter 2.6 SF, 55 GPM
    1.5 hp 1-speed pump
    pool DOB July 2012
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    I use the items in the links below. I still use a pillow. From what I understand it helps with ice relief.
    http://www.namcopool.com/pool/winterizi ... -plug.html
    http://www.namcopool.com/pool/winterizi ... ubber.html
    Mike
