Thread: Should CYA be stable or can it vary?
    Jul 2012
    Chandler, Arizona
    24
    The CYA level in my pool has been 70-80 for a long time and I've not had to add any Cyanuric acid. I just got back from a business trip and tested the pool for the first time in 4 weeks. Surprisingly, everything was still pretty good (pH a little high, but SWG kept chlorine good) except CYA had dropped to 55!
    Should CYA be pretty stable, or this type of drop normal?
    12,000gal Venetian glass tile. 4 Pentair Whisperflow (2x1HP, 2x1.5Hp), 1xPentair Waterfall pump (1HP), Triton II sand filter, MiniMax NT 400 heater, PC2000 in floor cleaner, Resilience A5 SWG, pHtek automated acid system, Paramount Clear O3 Ozne Generator.
    22,544
    Re: Should CYA be stable or can it vary?
    It's not uncommon for CYA to drop over the season. Have you had a lot of overflow? If so, that would explain it.
