This is my first time measuring everything. I'm just hoping someone can point out if I did something wrong and/or what to do next?
These were taken with a TF100 Test kit.
FC -1
Ph - 8.2
TA - 100
CH - 120
CYA - 0
I know right off the bat I need to add CYA. I'll get on that right away with the CYA in a sock recommendation I've read elsewhere on the site. I know I also need to add chlorine. According to the pool calculator, I need to add 315oz of bleach to get FC up to 5.
I'm going to do those two things right now. My question is do I try to take action on some of the other numbers (Ph/CH) right now too? Or should I wait to get FC and CYA in check before moving on to the other chemicals?
I also have a salt water generator hooked up that I've not turned on yet. SHould I do that now? Or get FC up to 5 and then kick it on?
FC -1
Ph - 8.2
TA - 100
CH - 120
CYA - 0
