Thread: Replacing the flex hoses on my pump system.
    I want to replace the flex hoses that came with my pool with PCV piping. I would also like to add another shut off valve and a couple of purge valves at the lowest points in the lines. About the pool and pump. It's an above ground pool with a Waterway Clearwater 2 cartridge pool filter system. I need to know where I can buy fittings with the correct thread size and what size pipe I should use.
    Thanks.
    22,542
    Re: Replacing the flex hoses on my pump system.
    Welcome to TFP.
    All the screwed fittings should be 1½" NPT. If the equipment is fairly close to the pool 1½" will be fine to use. Just buy all 1½" pipe and fittings. I'd get full port valves if I could.
    Thanks! I was worried about the threaded parts not matching up properly.
    I have everything replaced now. The origional reason for replacing the hoses was that the couplers the pool company installed were cracking and leaking. Now I have another leak. The gray plastic bulkhead exhaust port fitting is leaking where I screwed in my PVC adaptor. The leak is right at the mold seam. So now I have to drain some water, cut and remove the pvc pipe then replace the fitting. My pool is going to be green soon.
    22,542
    Get soem FC in there before you shut it down and you should be fine for a little while.
