Thread: TA Test Color Changes
    Just did an new fill on my hot tub and I'm going to use the BBB method since I had a great year using it on my pool. When testing TA I'm not getting the typical color changes. Color starts out a blueish green and changes to a yellow orange. Is this normal, I'm assuming I should just watch for the change.
    Thanks Jim
    17500 gallon Sharkline Morada PUR RTR 18X40 54 tall, 1.5 Hayward cartridge filter,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: TA Test Color Changes
    That's normal with high chlorine. You are correct that the change is the key.
