Thread: Should you power wash a cartridge filter?
    I have a StaRite PLM 150 cartridge filter. I read the sticky that talked about using a brass nozzle, but I has a small gas power washer (2200 psi) and want to know if I can use the power washer on it with out destroying or damaging the filter since they are very expensive to replace. Thanks.
    Patriot Arcadia 15' round 52". Pentair Clean and Clear 100 sqft Cartridge filter, 1HP Optiflow pump, Goldline Aquatrol SWG. 2 - 4'x20' solar panels roof mounted. All rigid PVC plumbing. Resin Solar reel with 8mil Thermo-tex solar cover. 14 x 12 deck.
    Ovation 15'x24'x52'' AG. Pentair System 3 150 SQ foot cartridge filter, 1 1/2 HP pump.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I'd expect you'd cut right through the filter. My pressure washer will groove concrete.
    Feb 2008
    Denton, TX
    5,061
    Actually, I have cleaned my cartridges following waterbear's sticky on how to do so and honestly, if you follow those directions, the little brass nozzle is really all that you need. The filters come clean fairly simply with a minimal amount of pressure.
    Craig
    Guest
    A power washer, even with the low pressure nozzle on it, can still damage the polyester fabric of the cart. It is not recommended by any of the major OEM and Replacement cartridge manufacturers.
    mas985's Avatar
    Pleasanton, CA
    11,742
    I use the brass nozzle method as well and I can attest that it is a winner. More than enough pressure and strength for cleaning. You should not need a power washer.
    Mark
