Thread: Auqabot reset??
    Auqabot reset??
    Hi all! This is my first post...I have an Aquabot (the orginal) that the power cord became wrapped around the cleaning roller. By the time I noticed it, it wasn't doing anything at all? No humming, no running, nothng. Just sitting in the bottom of the pool. The motor has only two seasons on it including this one. I checked the fuse in the power supply box.(and replaced it just to be safe) I was wondering if there was a reset button anywhere? Any advice would be greatly appreciated! Thanks in advance!
    Re: Auqabot reset??
    Hi Ajax. I do not believe there is a reset button on the unit. It's possible the aquabot damaged the cord. If that's the case, you will probably have to replace the power cord. It's not an inexpensive repair. If you're handy, you may be able to do it yourself. Good luck.
    Tom
    In gound vinyl L, ~41,000 gallons, Pentair Clean and Clear Plus 420 cartridge filtter, Pentair 2 speed WhisperFlo pump
