Results 1 to 7 of 7
Thread: Slip Proof Mats?
    Slip Proof Mats?
    Hello,
    New member here and this is my very first post We just had a semi-inground pool installed with a beautiful 7 foot slide. We are looking for some non-slip mats to put at the base of the slide and surrounding area so that our young children don't slip. Can anyone suggest something or perhaps a website.
    Cheers.
    Joanne
    Semi IG, Vinyl, Sand, Built in 2012, Lives in Eastern PA.
    Re: Slip Proof Mats?
    Indoor/outdoor carpet??
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    I'd check out a restaurant supply. There are rubber mats to prevent slips in kitchens where water and grease and tile floors make things dangerous.
    Quote Originally Posted by Richard320
    Thanks so much!
    Quote Originally Posted by crek31
    Thanks.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    We used these on an elderly neighbor's step, and they stayed strong throughout the winter and summer.
    http://www.walmart.com/ip/Incom-Manufac ... p/21153615
    Aug 2010
    New Caney, TX 77357
    184
    The big box stores have outdoor rugs / door mats with latex backing that might serve the purpose as well.
    20K gal, inground with attached spa, pebblefina plaster (bella blue), flagstone coping, moss rock waterfall, Sundek - Indian wheat, (2) Jandy PHPM2.0 (filter pump and waterfall), Jandy DEV60 DE filter, Polaris 280 pool cleaner, Polaris Halcyon PB4-60Q booster pump, Polaris 1.5 HP Air Blower, (2) Jandy WaterColors LED lights, Jandy LXI400P Heater, Jandy AquaPure PLC1400 SWG, Jandy AquaLink RS PureLink Controller and PDA.
