Thread: Drain cover
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Drain cover
    I need to remove my main drain cover. I removed the 2 screws but the cover won't budge. Any suggestions?
    Thanks
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    should come right up, try using a screw driver to pry it up
