Results 1 to 17 of 17
Thread: Whisperflo - motor replacement advice
    Recently, the motor started making a terrible high pitch sound. Probably bearings. I am thinking of replacing the motor + getting a seal kit, which should be relatively easy and probably cost the same as servicing the existing one.
    The motor that's installed is an AO Smith 3/4 HP and the pool has a 20,000 gallons. My questions:
    (1) Any recommendations as to where I should get the motor?
    (2) Is the existing motor sized correctly?
    (3) Any other thing I should know? I've never done anything like that but I am fairly handy.
    Thanks!
    Guy
    ~20k gallon IG plaster pool, Pentair 3/4HP Whisperflo, Pentair FNS Plus 48 DE filter, IntelliClor IC40 Salt Generator, Pentair Legend Platinum Robotic Cleaner
    38,449
    Re: Whisperflo - motor replacement advice
    There is always the option of going with a 2 speed motor. Depending on how your current one is wired, you might have to upsize the motor, but you would still save money on energy by running in low speed most of the time and only using high speed when you need it.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    I found the original sticker of the Whisperflo. It says:
    3/4 HP
    Service Factor: 1.27
    The AO Smith motor that's currently installed is 3/4HP / 1.65 SF
    I looked for replacement motors and found 2 AO Smith options: one with SF 1.25 and one with SF 1.65 - which one should I get?
    Guy
    38,449
    I am confused. The two scale factors are the same?
    You just need a 3/4 with scale factor 1.25 as a minimum to match the original.
    Sorry. A typo... should have said: "one with SF 1.25 and one with SF 1.65". I edited the original post. Thanks!
    Guy
    Qwaxalot's Avatar
    Jun 2012
    439
    As long as the HP times the service factor is sufficient for the pump's impeller, you're good to go. The impeller is the limiting factor. In other words any 3/4 HP motor with a service factor greater than 1.27 will do the job. The bigger service factor means that the motor won't work as hard.
    And, unless you have water features, 3/4 HP is fine for 20,000 gallons.
    EDITED to fix service factor typo (sorry)
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    mas985's Avatar
    Pleasanton, CA
    11,741
    Quote Originally Posted by Qwaxalot
    In other words any 3/4 HP motor with a service factor greater than 1 will do the job.
    I think you meant anything greater than 1.27 since that was the original service factor.
    Mark
    May 2009
    Youngsville NC
    395
    For the OP - what you need to look for in a motor is anything with a SFHP (SF x HP) rating of .9525 or greater. 1 HP motor with a SF of 1.0 would meet this as well. I can't comment on how its energy use would compare to the 3/4 HP with the 1.27 SF however, it would run the pump without overloading the motor..
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    Thanks!!!
    Guy
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by mas985
    You're right, I fixed it.
    I ordered a new motor, Energy Efficient SF 1.65 and 3/4 HP.
    This might be a silly question: when I remove the old motor from the pump, do I need to do anything with the valves/diverters to avoid getting soaked or would the valve in "filter" position prevent the water from coming back from the tank?
    Guy
    22,553
    If the pump is above the waterline you really don't have to do anything. If it's below the waterline you'll have to shut off the suction and return line. Since you've given us very minimal info about your setup we can't be of more help.
    I have been a pool owner for 2 years, so pretty much everything is new to me and I do not even know what information is needed
    The filter and pump are above water line. I was mainly concerned about the water from the filter tank coming back...
    Guy
    38,449
    What kind of filter is it? (add your pool and equipment info to your signature)
    Do you have a multi-valve on the filter that you can close?
    If not, some of the water will drain out of the filter ... not really a big deal. Or just open the drain valve on the filter.
    22,553
    You could always drain the filter if it's a concern.
    Signature updated! I just noticed that my valve has a "closed" position. That should probably help.
    Now, all that's left is to hope that my existing motor will live just a couple of days more, until its replacement arrives. It is making a terrible noise!
    Thanks for all the help! Much appreciated!
    Guy
    22,553
    Putting the multiport in closed will keep the filter from draining out when you open the pump.
    Since you have a DE filter, when was the last time you opened it and cleaned the grids well? If it's been a while I'd suggest taking this time to go ahead and do that while you have the system down anyway.
