Thread: Digital readout "hot"
    My goldline chlorinator screen reads "hot" and is not generating. When I change to supercholorinate, it starts generating and then cuts off again. When I get a reading of salination it is low (2400). What should I do to troubleshoot this and resume chlorination? Thanks for any help out there.
    Qwaxalot's Avatar
    Jun 2012
    439
    Re: Digital readout "hot"
    Quote Originally Posted by cjhurndon
    The temp sensor is in the cell.
    Try cleaning the cell. Have the salt level in the water tested.
    If the cell is older, and the cell is clean (no scale), and the variation between tested salt vs the goldline indicated salt, is greater than 500 ppm, you probably need to replace the cell.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Mine did that and I turned off the power and cut the breaker box to let it reset and it worked. Not sure if that will help but it is worth trying before you replace cell.
