Thread: main drain stop
    union beach n.j.
    99
    main drain stop
    i was wondrering if there is somthing to seal of my main drain other then a screw in cover, w/ pool still filled w/ water, somthing like a suction cup, just temperary for winter that i can install quickly holding my breath as i do not have scuba gear lol, i know this sounds silly but i figured i just had to ask, as this could help me eliminate the drain as a possible leak.
    20x40 IG vinyl, grecian style, 32.5k gal, hayward ec75a perflex d.e. hayward super pump 1 hp 80 gpm, 8 hr 38k gal turnaround
    Qwaxalot's Avatar
    Jun 2012
    439
    Re: main drain stop
    Try a rubber floor mat (with a smooth side).
    If that doesn't work you might try some visqueen (If the drain is actually leaking, water pressure will hold it in place)
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
