Results 1 to 7 of 7
Thread: Can't get seal to stop leaking
    Herndon, Va
    65
    Put my filter back together tonight, lubed the seal and tightened it all up and it leaked.
    Took it apart again, clean it as well as I could. Put lots of lube on before and after the rubber o-ring. Then I tightened it really tight.
    All was going well until the gauge read 20 psi and the started leaking really bad. Tried to tighten it up to get it to stop and it only got worse. Seems that the o-ring stretched when I tightened it up.
    What can I do to get this to stop leaking? Also, should the o-ring be cut in half, meaning it is just a long snake not an actual ring? And finally why would my psi be 20 when I just washed all the DE out of the filter?
    Thanks for any help.
    Jim
    ____________________________________________________________ _____
    IG 25,000 gallon concrete painted pool,
    KDI American Products Model# 583090 Titan SS Vertical Grid 48sq ft DE filter
    Sep 2009
    Greentown, IN
    914
    Re: Can't get seal to stop leaking
    You may need to get an new o-ring and give it another try if it has stretched. Sounds to me like you overtightened ... which can case the o-ring to buckle and/or stretch and water can leak past.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Herndon, Va
    65
    well I think I'm going to have to get a new o-ring. This one is broken and it's just not going to make it around the tank.
    I went to a few pool stores and can't find an o-ring. Problem is that we can't figure out which part number and because we don't know what year the filter was made.
    There seems to be two, one that was made before 94 and one that was made after and I have no way of knowing what year.
    Anyone have any idea on what to do? I could order the two o-rings, guy says it will take over a week to get one. This begs the questions, how do I keep my pool in good shape until I get one?
    union beach n.j.
    99
    "And finally why would my psi be 20 when I just washed all the DE out of the filter?
    on my perplex d.e. filter, 20 psi is past redline and dangerous, 7-8psi is normal for mine, but yours could be different, others im sure will chime in on that. did you replace the d.e. immediatly as soon as you turned on your pump after cleaning, if not that will cause your psi to rise.
    20x40 IG vinyl, grecian style, 32.5k gal, hayward ec75a perflex d.e. hayward super pump 1 hp 80 gpm, 8 hr 38k gal turnaround
    union beach n.j.
    99
    do you use chlor tabs? if so i think you will be fine using 3-4 3" tabs in a floater and run the filter for maybe an hour or as long as you can w/ that leak, per day, till you get your parts and then you will know exactly which one you have. or if you have a bypass run that as you would normally for the filter.
    Herndon, Va
    65
    Yes I'm using the floater right now. I just put the pump on recirculate so it doesn't go through the filter.
    Think I found the right o-ring, but it won't be here until probably Thursday because of the holiday.
    Herndon, Va
    65
    Decided to try a little trick...I cut the edges of the seal flat and then super glued them together. Put it on and it worked! So the filter is running like like this until the new seal comes.
    Thanks all for the help
