Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: What percentage is this muratic acid?
    http://www.wmbarr.com/product.aspx?catid=99&prodid=206
    Just bought some at Walmart and can't find out what percentage it is. I see on the data sheet it says 25% concentrate but I do not see that on the pool calculator. Anyone know?
    18x36 Grecian Vinyl; 8' Roman steps w/t 2 spa jets; cozy cove w/t 6 spa jets; 2 MD, 1 Skimmer, 3 returns; Hayward Ecostar, 30" Ranger sand filter; Hayward color logic 4.0 LED light; Hayward aqua logic; 2" PVC pipe 4 Jandy Valves
    Re: What percentage is this muratic acid?
    Also just read where it says not to use with chlorine type bleaches. Does all muriatic acid say this or did I get the wrong thing.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Yeah, no one really knows for sure what percentage it is other than it being <25%...not real helpful. Also, in general it is more expensive then the higher concentration 31.45% stuff. I would just return it and get the full strength stuff. I have never seen any reports of "other extra stuff" in it though, so if your desperate, you could just adjust the poolcalculator result by multiplying by this ratio 31.45/25, and put that much in then measure in 1/2 hour and adjust again if necessary.
    Quote Originally Posted by kyle11
    Never mix Muriatic Acid ( of any concentration) directly with chlorine, one of the products is chlorine gas. Adding them separately in a pool is fine however.
    Ok thanks linen. I will probably just use this and adjust like you said being it was only $6 for a gallon. Not worth the hassle of returning. Thanks again.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    The pool stores in my area sell 30% or 31.5% at 2 gallons for $10.
    chiefwej
    Starting ph was 7.8 best I could tell. Hard to tell the difference between 7.8 and 8.2. I have added 50 ounces so far waiting 30-45 min between time and it still has not changed. Should I add more or is 30 min enough time?
    Also would like to point out I am shocking the pool. I started out with a Ph of 6.8 or so I thought. Added 200 ounces of borax per pool calculator. Then tested today and ph showing 7.8-8.2. Just read oh can show off if chlorine levels are at shock value. Should I wait until the morning before adding any more ma?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Don't adjust ph when the FC concentration is above 10 ppm, it will read high.
    Ok thanks. Live and learn. I will wait until tomorrow afternoon to get a good reading when fc comes down if I pass over night test.
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    That is very weak muriatic acid. I got something similar at HomeDepot as they don't carry the higher concentration here in Durham NC. I ended up adding 6 cups to lower pH .5pp. I realized it was weak when I opened the bottle and couldn't smell anything. Good thing tho...it's so weak I was able to use straight up to clean deck chairs this year.
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
    I am wondering the same thing . I Bought Muriatic Acid from Home Depot it says :
    Hydrogen Chloride......... 14.5%
    Inert ingredients..... .........85.5 %
    Total ...............................100%
    How do I read this on the pool calculator my guess was 14.5 %
    I just want to check here that I am using the right number on the pool calculator ?
    Thanks
    6000 gallon Viking fiber glass pool Blue Safire with 250gallon Spa spill over , (Frog chlorinator not hooked up ) , Jandy filter cartridge, Sta-Rite heater 333 Btu , Liquidator
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes, the Hydrogen Chloride is the acid concentration that you want to put into The Pool Calculator.
    Quote Originally Posted by chem geek
    Thanks Chem Geek ! No wonder I have been having problems dropping my PH levels
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    When I'm inside at home depot the weak stuff is in the paint section. The strong stuff is outside but under cover.
    - Sent using Tapatalk
    I can tell you it takes almost twice as much Walmart brand to see a difference in pH. We were trying to figure out why my pH would not go down after using the prescribed amount of MA.. Until I used the "good stuff!
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Because of the difference in strength, MA is the one item that I find is cheaper at the pool store than anywhere else. It's twice as strong as the big box stores and cost about $5 per gallon.
    chiefwej
    WHen you say stronger MA what should I be looking for ?
    For sure I will try and find it more then what I have now which is 14.5 percent which I think I bought at Home Depot
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    The pool stores in my area carry either 30% or 31.5%. Lowes and Home Depot carry 15%. The price is about the same.
    chiefwej
    Quote Originally Posted by nomad26
    It will say on the jug - 31%
    WARNING - Don't stand downwind when you open the bottle.
    Helen
  20. Back To Top    #20
    Thanks I will check my pool store
