Thread: New Pump Advice Please.
    16 x 32 inground circa 1973. Fiberglass tub. 1 deep end skimmer, 1 shallow end suction, 1 deep end return, 1 shallow end return. 8 ft deep slopping sides, 3 ft shallow end. No floor drain. 1 1/2 piping. Orig pump .75 hp. Last 15 yrs using old 1 hp ITT Marlow found at yard sale. Impeller needs rebuild but thinking of just replacing due to efficiency/parts availability.
    Any suggestions?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: New Pump Advice Please.
    I would go with a small two speed. Here are a few of my favorites that would work well with your setup:
    Pentair SF-N2-3/4A (115v)
    Pentair SF-N2-1A (230v)
    Hayward Super Pump SP2607X102S (230v)
    Mark
    Thanks MAS, but I beg ignorance.......... What is the difference in a 2 speed?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Energy costs. Low speed uses about 75% less energy than high speed or a single speed pump. However, it has about half the flow rate so you need to run it twice as long but you still net a 50% reduction in energy use.
    Mark
    May 2011
    Orillia, ontario, canada
    50
    I find that I'm running my pump way less than my old single speed. I bought a dual speed 1 hp and I only use high speed when manually cleaning.
    I also bought a timer and I run low speed 10 hrs a day
    I have a 15k L pool
    No problems with Algee yet
    I do swim every day.
    Approx 74,000 liter inground vinyl pool 12x32, laser 225 sand filter, Hayward 2 speed pump + old pool heater.
