Thread: My pool readings from the pool store
    OK I have been trying the BBB method for the past month and I cant seem to get my PH balanced or my chlorine to stay. It looks like my CYA may be the culprit and I have started a water change and am changing my sand out and going with zeo brite.
    FAC- trace amounts
    TAC -1.0
    PH 7.2
    TA -40
    CH-190
    CYA- 120
    TDS 950
    Phosphates trace.
    Already have the water drained down and the sand changed. I am now cleaning the old silcone caulk from around my inlets and skimmer and recaulking with silicone. When I started scraping the old shrunken caulk away from around the inlets I found green algae. same for the skimmer basket, so I took a spray bottle of straight 6% bleach and sprayed till it ran clear.
    My pool is a modified grecian style fiberglass and the caulking was original and 6 yrs old si I guess this maintenance task was due.
    12,500 Gallon Fiberglas spool
    Hayward S210 Sand filter
    Hayward Superpump
    Tulsa OK
    been using BBB since April 2008
    Guess What?????
    BEEN ALGAE FREE SINCE APRIL 2008
    30,421
    Re: My pool readings from the pool store
    Are these test results before or after your refill?
    I addition to reducing CYA you should also increase your TA with baking soda. You should bring TA up to 80 or 90.
    Thanks for the advice. I have made the trip to Walmart and have the 4 lb Arm and hammer boxes and 20 mule borax, sitting on the sidelines. With such a large drain and fill ( about 40 %) and the possibility of another one if needed, I thought I should just wait till the CYA is lower before throwing anything else at it.
    Love my pool, hate pool maintenance
    Hayward Superpump
    Tulsa OK
    Guess What?????
