Results 1 to 14 of 14
Thread: Lulupalooza 1st TEST w/T-100
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Well here they are, the very 1st test from the pool
    FC: 0.0
    CC: 0.0
    PH: 7.2
    TA: 20
    CH: 170
    CYA: <20 (the dot never disappeared- it just magnified! I was at the top of the tube)
    Temp: 79 degrees
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Guest
    I assume this is the fill water with no added chemicals.
    That is a reasonable starting place. Now you need to add chlorine, baking soda for the TA and stabilizer/conditioner for the CYA.
    Mar 2008
    Evans, GA
    323
    Quote Originally Posted by waterbear
    yes, just straight fill, no chems addes as of yet.
    *~ Laura ~*
    TF-100 Test Kit
    Mar 2008
    Evans, GA
    323
    So I am estimating the pool being 17100 gallons if I fill it 48 inches. It's telling me to add 142oz chlorine bleach, 321 oz of baking soda and assuming the CYA is about 10ish about 68 oz of stabilizer.
    *~ Laura ~*
    TF-100 Test Kit
    I would start with about 200 oz of baking soda to get into the 70 to 90 range. Also, you probably want to add the CYA in two steps and test in between to see where you are. That will take longer, but helps you avoid over shooting. Otherwise you numbers look reasonable.
    Also, keep in mind that with your current low CYA level the chlorine will go away quite quickly. Once the CYA starts to dissolve you will need a higher FC level, but won't need as much bleach to maintain it.
    30,405
    Quote Originally Posted by lulupalooza
    1. I like the bleach amount.
    2. I'd buy that much baking soda, but not put all of it in at once...probably 1/2 to 2/3 then wait 24 hours and test again.
    3. You'll have 0 stabilizer as your starting point. If you're shooting for a target of 40ppm, you'll need about 5.5 lbs. Again I'd suggest putting in about 4 lbs, waiting three or four days, and then test for it again and adjust.
    4. Keep in mind your chlorine will go away very quickly. you'll probably need to put in 1/2 gallon or so daily for the swim season.
    Mar 2008
    Evans, GA
    323
    Thanks Guys!
    I went ahead and added 3 lbs stabilzer- will go get more tomorrow, 174 oz bleach and 6 lbs baking soda. Will test again tomorrow evening. And go from there.
    *~ Laura ~*
    TF-100 Test Kit
    Mar 2008
    Evans, GA
    323
    Ok here are my test results at 5:30pm 5/12/08
    CL: 5
    pH: 7.2
    TA: 50
    CYA- NOT TESTED
    Added 2 lbs baking soda
    *~ Laura ~*
    TF-100 Test Kit
    30,405
    Lulu,
    Just like the Jefferson's, you're "Movin on up!"
    Looks like everything is headed in the right direction. You have a good grasp of the principles involved.
    Mar 2008
    Evans, GA
    323
    Here's my test for today
    FC: 3
    CC: 0.0
    PH: 7.2
    TA: 60
    CH: 20
    CYA: 30
    I was wondering about the CH level. But with a vinyl pool does it matter? CYA is definately coming up and I haven't had to add any bleach since I put in that 1 large jug 3 days ago.
    *~ Laura ~*
    TF-100 Test Kit
    30,405
    Yes, but you'll need another jug tomorrow. You will drop another 2ppm tomorrow and you really shouldn't get quite that low. I'd try to keep the FC between 3-6ppm.
    Mar 2008
    Evans, GA
    323
    Thanks Dave. I went ahead and added 1/2 of 174 oz bleach and the rest of the CYA about 1.5 lb. Hopefully that will rise the CYA levels where they need to be and I will retest that on Sunday.
    Luckily our pool is pretty much half shaded all during the day until after 3 pm, so it's really only getting about 3-4 hours max of full sun per day.
    *~ Laura ~*
    TF-100 Test Kit
    Moved from another thread. JasonLion
    Ok I think we are on the ball here.
    The blue test kit thingy says CL is 4-5 looks closer to 4
    FC 3.5ppm
    CC 0.5
    TC 4.0 ( so I assume it means the blue test kit is correct?)
    pH: 7.2 (doesn't seem like its moving despite adding 10 lbs baking soda over a period of the last 3 days. Though it might be about 7.3-7.4 range the color on the test thingy isn't as light as the 7.2 and isn't as dark as the 7.5)
    TA is at 70
    This morning I added 87 oz bleach and 38oz borax. I will check the CYA again prolly around Sunday.
