Thread: BBB rocks!
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    BBB rocks!
    We have not used our pool for the last month and all I did was make sure I added 2-3 cups of chlorine every few days, kept the solar cover on at all times and ran the pump 24/7. After a month of only adding chlorine, I finally was able to get to the pool, to test the chemical levels, brush the sides and vacuum the debris off the bottom.
    Still NO ALGAE and all the chemical levels stayed within range. (Still planning on doing the OCLT just in case.)
    If I had been using the pool store stuff like last year, I would not be excited, but instead worked up over the mess I would have had.
    Thanks TFP and BBB rocks!
    16 x 28 Doughboy Mystic Garden AGP with 7' deep end (used expandable vinyl liner) ~11,800 gals. Deep end main drain. Thru-the-wall skimmer, one return at deep end. Media Master 150# sand filter. Doughboy PowerPak II pump, 1 hp. Pentair MinimaxCH 150m natural gas heater. Polaris 65 when it feels like working . TF-100 test kit. No longer 'pool stored' 6 years and counting. In sunny but fickle metro-Detroit.
    38,524
    Re: BBB rocks!
    You were adding bleach often enough and were reward ... nice work
    Butterfly's Avatar
    South Carolina
    10,045
    Re: BBB rocks!
    You're done SLAMing when:
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    Re: BBB rocks!
    Did OCLT. FC only dropped by 0.5.
    Actually, I misspoke.
    BBB is great. TFP Rocks!
