Thread: Roughly how much aeration to raise pH?
    There's never really been enough water pressure or flow to feed my slide, so I recently put my Harbor Freight utility pump to work - 3000GPH makes a HUGE difference! Then I got to thinking; "hey, lookit all those bubbles - that oughta be a good way to aerate and get the pH back up after I dose with MA to lower the TA".
    I added MA 4 days ago, aiming to get the TA down from 170 to maybe under 100. I've left the pump running for the last 5 days, thinking surely that'd be enough to tell a difference - but nope, no change in pH, it's been steady at 7.2 while the TA has slowly dropped down to today's 110 (which may be an all-time low for this pool).
    Last Friday I shocked the pool up to FC=22, now down to 11.5, CYA at 60. I was told that high FC will make pH read high incorrectly...so is my actual pH 6.8 or lower?
    Here's a pic of the slide / aerator, you guys think this would be any good at aerating?
    In-ground Plaster 40' X 80' 144K gallon pool w/ 2 pumps (old Challenger bronze and newer Challenger II plastic) and 2 large sand filters (Pentair Triton 140's). Built in '85, in bee-yootiful shady Buffalo Gap, West Texas.
    May 2012
    Mesa, AZ
    40
    Re: Roughly how much aeration to raise pH?
    I'm pretty new here, but I believe I have read on here several times that the pH test will not be accurate anytime FC is above 10ppm. So may want to wait until FC drops a bit more and retest.
    15k gallon 17'x34' IG Pebble Play Pool (3x5x3), 1HP Emmerson 1081 Pump (x2), Pentair TR-100 Sand Filter, PCC2000 Paramount in-floor cleaning system
    Mar 2007
    San Rafael, CA USA
    12,082
    With your FC down to 11.5 ppm, your pH reading is probably accurate if you don't wait very long in taking a reading (i.e. don't let it sit too long -- read it soon after adding the R-0014 or R-0004 (depending on test kit). As for aeration, the water falling from the slide is only a little aeration. Compare to this one, this one or this one. Or you can hope for a hail storm (look after around 1:30 into the video).
    I assume you have been using only a hypochlorite source of chlorine. If you've been using something acidic such as Trichlor, then that would offset any pH rise from the aeration.
    38,290
    Quote Originally Posted by chem geek
    Holy COW ... I am laughing hysterically ... that is crazy
    WOW!!!
    So that's the goal then, huh? Hmm... I've got this outboard motor....
