Thread: Plumbing and next payment
    Hi
    My build was started Monday. The plumbers have come and done most of the plumbing as far as I can see.
    The PB's office is asking for the payment, however I don't see any of the plumbing for the spa except for infloor cleaning. There is no plumbing for any of the jets. This is a raised spa, would that make a difference as to when the plumbing for that gets done? Like after the steel goes in?
    Thanks in advance.
    Inground shotcrete, deco & glass tile, 30' x 15', 6 ft depth, 401 sq. ft., Sta-Rite VS3050 pump, 400 Sta-Rite Mod Media Filter, Sta-Rite Max-E-Therm Heater, Intellichlor Salt Chlorinator, PV3 Infloor cleaner, IntelliBrite Led Spa & Pool lights. Quartz - Blue Cayman finish.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Plumbing and next payment
    For a spa, it is usually easier to plumb after the rebar is in place so it can support the pipes. Also, it is much harder to rebar after the plumbing is in so it works both ways. But they should have specified what was suppose to be done for each payment.
    Mark
    Thanks mas985!
    The payment schedule says "after plumbing" but it didn't say that the spa would be done after the rebar (which by the way, was done today).
    The owner of the pool company actually called me this afternoon and explained it just as you have.
    Thanks again.
