Results 1 to 14 of 14
Thread: Can this really get any worse?
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Hi all!
    Well, after finally getting the pool full of water. I am now facing another set of issues. Last night we plugged the pump into the very shoddly done electical outlet and WHAM! Seen a flash up by my AC unit and the pump immediately shut off and wouldn't cut back on. So I ran a drop cord and plugged into AC outlet on the side of the house and it ran fine. Only other problem is that water was spewing from the hose to the pump housing. But DH and I are going to replace all the hosing with PVC pipe like on an I/G. As far as the electrical outlet is concerned. I didnt think you could hook up to the AC unit and that wasn't suppose to be done- he came while I was gone and this is what I came home to. Was suppose to run it to the electrical outlet that was pre-existing on the outside of the house. His excuse was that it was to hard. BTW this dude works for the pool company. I am going to make him redo the entire thing I don't want it hooked to my AC unit. We replaced our AC/Heating system 3 yrs ago
    Anywhere here are the pics. I don't think this is up to code. Arrrhhhhh
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    30,432
    That's pretty rough looking electrical. I'm not qualified professionally, but it looks like you've got some code violations.
    Mar 2007
    Texas
    444
    Well I am an Electrical professional, and that electrical work is not only unprofessional but is also NOT to code. How did you pass inspection? I would demand to see his license and if he does not have one I would turn him into the city, I would also have someone other then him check your AC unit for any damage, I would also tell the PB that he is to use someone else that is licensed to redo the work.If this guy does have a license he needs them taken away.Do not let this pass by even if they do fix it.
    27' Round AG, 17,200 gallons, sand filter
    Mar 2008
    Evans, GA
    323
    I am prettymuch upset with myself since I paid [edit:jjparrish] him already. I was gone most of the day and he showed when I was not a home and did this. Any I am going to clean house come Monday. NOTHING they did was without error.
    *~ Laura ~*
    TF-100 Test Kit
    Mar 2008
    Evans, GA
    323
    Quote Originally Posted by Poolidiot
    There is NO inspection. I called the county and asked before hand did we need a permit of anykind. And none was required. Only that the ladder be removed when the pool was not in use. I am going to find out who is the owner of this company. I am really quite disappointed by this entire ordeal to say the least.
    The orange drop cord is what I put there to see if the pump would run and that is how its running right now. But still it shouldn't be hooked to the AC I feel. If the pool shorts out something wouldn't it affect the AC unit?
    *~ Laura ~*
    TF-100 Test Kit
    Mar 2007
    Texas
    444
    Quote Originally Posted by lulupalooza
    Well there is STILL the NEC that has to be followed and any real electrition would know that
    Yes and that is why I said I would have someone come check out your AC unit at the PB cost.
    The most likely thing that will happen is that the circuit breaker will trip, turning off the AC. However, it is remotely possible that the AC wiring or the AC it's self could be damaged. What I can see in the pictures is very very wrong and it worries me that there could be worse things wrong that we can't see in the pictures. You should turn the AC breaker off, if it isn't off already, until a licensed electrician fixes it.
    Mar 2007
    Morris, IL
    477
    Underground romex right out of the side of the switchbox, directly into the ground, ran to an outlet that is almost set on the ground. Any rain will trip it. I would put a post in and mount it to it, along with a switch to be able to turn it on and off. I put mine through the pad that I poured to set my pump and filter on.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    A/C units are usually 220V; if the jackleg didn't know what he was doing, he possibly wired the pump across the two phases, which would explain the arc when you turned the pump on.
    The electrician that installed my feed drove a steel mounting post in the ground and attached the outlet box to it. I didn't much like that setup, so I pulled the steel post out, planted a piece of pressure-treated 4x4, mounted the outlet to it, and added a switch to control the outlet, too. I didn't set the post in concrete, though. so far, so good.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Mar 2008
    Evans, GA
    323
    Well the jackleg came yesterday and disconnected from the AC unit,so everythng is just laying where it's at. He was suppose to come back today and re-do everything. But I have called and called to no avail. Finally he called after I called the shop looking for him and with an attitude said that the day isn't over yet that he's waiting to finish a job and get some money to come re-do mine. Point is that for the past 2 weeks I have literally put everything on hold, even missed 3 days of work for something that I was told would take 2 days, 3 tops! Jerkleg said and that I didn't need to be there when he came, if he comes today.
    Well, I have tried to verify his electrician license with the name he gave me and in GA its a no go and in SC the only thing that comes up is a burgler alarm license in Charleston. This is not a good sign at all! Just like I can't practice real estate without having that state license. He can't do electrical work without having that states license!
    So tomorrow I am calling the owner of the company. I just texted the jerkleg and said I was unable to verify his license and to please produce it when he comes back out. Guess who called within 30 seconds,LOL
    I just want this all done and overwith so we can hopefully start enjoying the pool without any problems. Is that so much to ask????
    Sorry for the rant, but this is not what I expected at all. Just my luck I guess.
    *~ Laura ~*
    TF-100 Test Kit
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Lulu, for everyones info here in the SC and GA did you use the co. I warned you about. If so let us know as this will be a double confirmation to steer clear of this co.
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    Mar 2008
    Evans, GA
    323
    Quote Originally Posted by whoozer
    Yes, It was Griffin Pools and Spas. I know they have 4 or 5 locations in the Columbia/Lexington, SC area as well as one in the Augusta, GA area.
    BOTH the pool installer and the guy doing the electrical came like ASAP ( THEY JUST LEFT!) after I said I was going to call the owner if I was not completely finished with all of this by tomorrow evening. Only thing left is to complete the electrical, (took care of the box on the house. I told him I want a 4x4 with the green metal lock box outlet that I seen at home depot and that and the pool light box mounted to that cemented 4x4, fix the pool light and bring me the missing handrail for my smartstep ladder.
    The support poles/beams that hold up the wall that had issuses with the off centered pavers has been resolved and is level thankfully!
    For the record, in our area there are only 3 companies that do AGP. one of those being Doughboys. And they were well out of our price range, pushing into the 7k +. For that I would start looking at I/G's if I am going to invest that much money. Plus I wanted the option of being able to take down the pool if we ever move and our house turns back into a rental. I did see previous builds/references. The p/b assured me that this is a very rare occurence. I think he was trying to run 2 crews at once and I got stuck with the not so good one, while the p/b and the good crew did more builds and had to come fix the two dodo's messes.
    Just so glad this site is here to help all us people who are lost at this pool stuff. But I am learning!
    *~ Laura ~*
    TF-100 Test Kit
    Fayetteville, Arkansas
    220
    Wow ... I would attempt to contact the owner or an authorized decision maker of the company to get that straightened out quick. If you don't get any satisfactory action with that approach, there's always the Consumer Fraud Division of the State Government or the BBB. That is just wrong.
    20x40 30,000 gal IG Liner, Pentair II Sand
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    This particular builder has at least 20 complaints against him in the BBB in SC. I had unfortunately dealt with them on a spa. The day the thing arrived it had a crack in it and leaked. They kept telling me I was "crazy". Until I took pictures and video of the leak. IMO the BBB doesn't give two hoots about whether a business is bad or not they say they are mediating but do NOTHING!! I still have a leaking spa that supposedly has a 10 year against leaks warranty but they won't do a dang thing about it! The leak is just one small issue with the spa. BEWARE OF THIS COMPANY!
